.NET 6.0 from extension v1 to v2
Hi, everyone!
I am migrating our .NET 6.0 app, which was done with the v1 extension using the provided template. I have successfully install the new extension following this documentation
Application Development - .NET Example | Toradex Developer Center
I was able to debug and deploy the application without any major problems. for the moment I modified the docker file, docker-compose add all the nugets package and all the package needed for the app.
The problem comes with the display environment variable, it seen the windows forms don’t find the display variable. as i say in the version V1 of the extension this variable it sent as environment variable using:
env ENV DISPLAY=:0
At the moment, when sending the variable, it is not respected by the container, since when using docker inspect CONTAINER ID --format "{{.Config.Evn}}" ls variable is not displayed correctly
I would like to know what I am missing; this is the docker file I am using
 # ARGUMENTS --------------------------------------------------------------------
 # Board architecture
 ARG IMAGE_ARCH=
 # Base container version
 ARG BASE_VERSION=3-6.0
 # Application Name
 ARG APP_EXECUTABLE=t1
 # BUILD ------------------------------------------------------------------------
 FROM mcr.microsoft.com/dotnet/sdk:6.0 AS Build
 ARG IMAGE_ARCH
 ARG APP_EXECUTABLE
 COPY . /build
 WORKDIR /build
 # build
 RUN dotnet restore && \
 dotnet publish -c Release -r linux-${IMAGE_ARCH} --no-self-contained
 # DEPLOY -----------------------------------------------------------------------
 FROM --platform=linux/${IMAGE_ARCH} \
     torizon/dotnet:${BASE_VERSION} AS Deploy
 ARG IMAGE_ARCH
 ARG APP_EXECUTABLE
 ENV APP_EXECUTABLE ${APP_EXECUTABLE} DISPLAY=:0
 RUN apt-get -y update && apt-get install -y --no-install-recommends \
     # ADD YOUR PACKAGES HERE
 # DO NOT REMOVE THIS LABEL: this is used for VS Code automation
     # __torizon_packages_prod_start__
     alsa-utils:arm64 \
     libasound2:arm64 \
     libgpiod-dev:arm64 \
     tzdata-bookworm:arm64 \
     libx11-dev:arm64 \
     libgdiplus:arm64 \
     # __torizon_packages_prod_end__
     && apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
 # copy the build
 COPY --from=Build /build/bin/Release/net6.0/linux-${IMAGE_ARCH}/publish /app
 # ADD YOUR ARGUMENTS HERE
 CMD [ "./app/t1" ]
and the docker-compose
version: "3.9"
services:
  t1-debug:
    build:
      context: .
      dockerfile: Dockerfile.debug
    depends_on:
    - weston
    image: ${LOCAL_REGISTRY}:5002/t1-debug:${TAG}
    environment:
      - DISPLAY=:0
    network_mode: host
    devices:
    - '/dev/gpiochip2'
    - '/dev/gpiochip4'
    - '/dev/snd'
    - '/dev/verdin-uart1'
    - '/dev/verdin-uart2'
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
      - type: bind
        source: /dev
        target: /dev
      - type: bind
        source: /dev/disk/by-label/otaroot
        target: /dev/disk/by-label/otaroot
      - type: bind
        source: /dev/dri
        target: /dev/dri
      - type: bind
        source: /etc/localtime
        target: /etc/localtime
      - type: bind
        source: /etc/timezone
        target: /etc/timezone
      - type: bind
        source: /home/torizon/fonts
        target: /usr/share/fonts/truetype/
      - type: bind
        source: /home/torizon/lx7
        target: /home/torizon/lx7
      - type: bind
        source: /var/run/dbus
        target: /var/run/dbus
    device_cgroup_rules:
    # ... for tty0
    - "c 4:0 rmw"
    # ... for tty7
    - "c 4:7 rmw"
    # ... for /dev/input devices
    - "c 13:* rmw"
    - "c 199:* rmw"
    # ... for /dev/dri devices
    - "c 226:* rmw"
    ports:
      - 2222:2222
  t1:
    build:
      context: .
    image: ${DOCKER_LOGIN}/t1:${TAG}
# TODO: we are using bullseye here because an issue with xwayland on bookworm
  weston:
    image: torizon/weston-vivante:3
    environment:
      - ACCEPT_FSL_EULA=1
    # Required to get udev events from host udevd via netlink
    network_mode: host
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
      - type: bind
        source: /dev
        target: /dev
      - type: bind
        source: /run/udev
        target: /run/udev
    cap_add:
      - CAP_SYS_TTY_CONFIG
    # Add device access rights through cgroup...
      # ... for tty0
      - "c 4:0 rmw"
      # ... for tty1
      - "c 4:1 rmw"
      # ... for tty7
      - "c 4:7 rmw"
      - "c 13:* rmw"
      - "c 199:* rmw"
      - "c 226:* rmw"
Greetings @Isaga,
On my side setting an environment variable seems to work. Here’s what I did:
  • Create a new .NET 6.0 project via the provided template
  • In the new project modify the default docker-compose.yml like so:
version: "3.9"
services:
  test-debug:
    build:
      context: .
    image: ${LOCAL_REGISTRY}:5002/test-debug:${TAG}
    environment:
      - DISPLAY=:0
    ports:
      - 2222:2222
  test:
    build:
      context: .
    image: ${DOCKER_LOGIN}/test:${TAG}
  • Start the deploy and debug process.
Once I did that I examined the created container and I can see DISPLAY is being set properly:
torizon@verdin-imx8mm-06827778:~$ docker inspect a --format "{{.Config.Env}}"
[DISPLAY=:0 PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/dotnet LC_ALL=C.UTF-8 DOTNET_ROOT=/dotnet APP_EXECUTABLE=test DEBIAN_FRONTEND=noninteractive]
By the way I noticed you misspelled “Env” in your docker inspect command, was that just a typo when you created this question?
In any case setting the DISPLAY variable from the compose file should work as I’ve shown. I’m not sure what’s happening on your side. Are you sure the DISPLAY variable isn’t being set in your container? Or maybe your application is failing for some other reason?
