Hello Support Portal,
SOC: IMX8QM
We have connected the Dual Channel display on the LDB2 node and the Single Channel display on the LDB1 node.
Dual Channel Display: 1920X720
Single Channel Display: 1280X800
The android is detecting both the display
Currently Android considers Single channel 1280X800 Display as a primary display and a Dual channel 1920X720 display as a secondary display.
What we want :
Dual channel display - primary
Single channel display - secondary
We have tried following things
- First we connect the Dual channel display and then after some time we connect the single-channel display but still, the single-channel display is considered as a primary display
Note: If we disable the single-channel display node from the device tree then the dual-channel display is considered the primary display.
