I’m currently working with a Colibri i.MX6ULL module mounted on an Aster Carrier Board, and I need to flash a Yocto-based image that is configured to support Python. I’m looking for advice or a guide on how to properly configure and flash this image. Here are some specific points where I could use guidance:
- Building the Image: What steps should I follow to include Python in my Yocto image? Are there specific layers or recipes in the Toradex meta layers that I should include to get Python support?
- Flashing the Image: Once I have my image built, what is the recommended procedure to flash it onto the Colibri i.MX6ULL using the Aster Carrier Board? Are there tools or commands provided by Toradex that I should use?
- Verification: After flashing, how can I verify that Python is properly installed and functioning as expected on the device?
- Potential Issues: Are there common pitfalls or issues that I should be aware of during this process? For example, issues related to hardware compatibility, software dependencies, or configurations?
I appreciate any documentation, tips, or personal experiences you can share regarding this process, especially from those who have worked with Python on the Colibri i.MX6ULL and Aster setup.
