I finally decided I couldn’t live with having my c# code getting blocked by garbage collection and went to offload my logic code into a native code .dll. I used the __declspec(dllexport) for my functions to make them visible from the .dll and did manage to call them from my c# code. One thing I can’t figure out is when I start a continuous thread in my native code, it blocks the form from which I call it from.
This is the example code for my .dll file
#include <windows.h>
#include <stdio.h>
#include "gpio.h"
HANDLE hGpio; //handle for the gpio
BOOL runLEDflash = FALSE;
HANDLE hToggle96;
extern __declspec(dllexport) BOOL runLED(DWORD interval)
uIo pin96 = COLIBRI_PIN(96);
BOOL ledState;
BOOL success;
// === Initialize GPIO library. ===
// We don't use registry-based configuration, thus we can
// pass NULL go Gpio_Init()
hGpio = Gpio_Init(NULL);
ASSERT(hGpio != 0);
success = Gpio_Open(hGpio);
ASSERT (success);
// === Io Manipulation ===
// Configure the pin to act as GPIO (as opposed to an Alternate function)
// Set it to Output, High
Gpio_ConfigureAsGpio(hGpio, pin96);
Gpio_SetDir (hGpio, pin96, ioOutput);
runLEDflash = TRUE;
while(runLEDflash){
if (ledState == 0)
ledState = 1;
Gpio_SetLevel(hGpio, pin96, ioHigh);
else
ledState = 0;
Gpio_SetLevel(hGpio, pin96, ioLow);
Sleep(interval);
return 0;
extern __declspec(dllexport) void runThread(void)
DWORD ThreadID;
hToggle96 = CreateThread (NULL, 0, runLED(50), 0, 0, &ThreadID);
//printf("Thread Started!"); //this never gets a chance to run!
return 1;
extern __declspec(dllexport) void killLED(void)
return 1;
And this is how I call it from my c# form.
[System.Runtime.InteropServices.DllImport("dllcreationtest.dll")]
static extern void killLED();
static extern void runThread();
private void button1_Click(object sender, EventArgs e)
runThread(); //this should create a thead in the native code and run it indefinitely
MessageBox.Show("this code never executes because runThread blocks it");
private void button2_Click(object sender, EventArgs e)
killLED(); //this should kill my logic thread if needed
I originally called the runLED function, but after that blocked, I decided I needed to create a thread that would run that particular function, yet the runThead function blocks as well! I’m clueless as to how the .dll is interfaced with my c# to make it block everything.
Any help or sugguestions are greatly appreciated. I’m hoping I can built this up to where I can send a class for the data configuration from c# (if that’s possible) so that all my logic code will run as native code at a high priority, and will pass off the results back to the c# code which handles all the ethernet, SD, and interface functions.
Thanks!
Matt
