Problem 1)
While performing production programming of VF50 module serial no 08406732. Once uboot is loaded, pressed space at uboot menu, and issue command nand erase.part ubi we are getting below error:
NAND erase.part: device 0 offset 0x200000, size 0x7e00000
Skipping bad block at 0x013c0000
Skipping bad block at 0x07f80000
Skipping bad block at 0x07fa0000
Skipping bad block at 0x07fc0000
Skipping bad block at 0x07fe0000
See attached file 08406732.txt for more deatils.
Problem 2)
At uboot for module serial number 08407182 we are getting below error.
VF50 Serial number 08407182 has below CRC warning:
*** Warning - bad CRC, using default environment
Please find attached 08407182.txt file for more details.
We tried erasing nand as suggested on below two links for above two problems but still problem persists:
and
About 10 new boards are shown this nand erase problem and Bad CRC problem.
