Hi sir,
At the time booting the below error coming , now what should i do ,
In this which pin is exact problem.
End trace message coming
Hi sir,
HI @bharatsurendra,
Thanks for writing to Toradex Community.
Regarding your question to understand better please provide and share more details.
Ritesh Kumar
Dear Sir,
Please find the log file
CCCB ENTRACE ERROR MESSAGE.odt (26.1 KB).
Actually we loaded the image files in one carrier board , then there is no issue in errors in that process and SOM is also completely booting fine.
Now i changed the carrier board with my internal design , in that SOM is struck in Booting process at End trace line.
Can you please suggest the in which section was not satisfied foe pins of SOM, why this problem particular carrier board only.
Hi @bharatsurendra ,
This suspect that the issue might be related to your customized carrier board.
We have no idea what changes you have made. Please let us know the what modifications you have done.
Also do tell us if you have made any modification in the image.
