Mwifiex driver - iMX8QP 2GB WB V1.1B
I submitted this last week via email during the upgrade, so reposting here just in case. Am working with an Apalis iMX8QP 2GB WB V1.1B SOM, and I’m building an image via Yocto using the tdx-xwayland distro off the 5.3.0-devel-202106 tag in the toradex-manifests repo.
When I boot the SOM, the onboard wifi comes up just fine and I am able to connect to a network no problem. However, periodically, the wifi driver appears to jettison itself and has to be re-downloaded onto the card. Here are the kernel messages it spits out when that happens:
[168814.437745] mwifiex_pcie 0000:01:00.0: mwifiex_cmd_timeout_func: Timeout cmd id = 0x107, act = 0x0
[168814.446822] mwifiex_pcie 0000:01:00.0: num_data_h2c_failure = 0
[168814.452850] mwifiex_pcie 0000:01:00.0: num_cmd_h2c_failure = 0
[168814.458783] mwifiex_pcie 0000:01:00.0: is_cmd_timedout = 1
[168814.464368] mwifiex_pcie 0000:01:00.0: num_tx_timeout = 0
[168814.469868] mwifiex_pcie 0000:01:00.0: last_cmd_index = 3
[168814.475366] mwifiex_pcie 0000:01:00.0: last_cmd_id: 07 01 07 01 07 01 07 01 07 01
[168814.482952] mwifiex_pcie 0000:01:00.0: last_cmd_act: 00 00 00 00 00 00 00 00 00 00
[168814.490633] mwifiex_pcie 0000:01:00.0: last_cmd_resp_index = 4
[168814.496574] mwifiex_pcie 0000:01:00.0: last_cmd_resp_id: 07 81 07 81 07 81 07 81 07 81
[168814.504592] mwifiex_pcie 0000:01:00.0: last_event_index = 4
[168814.510266] mwifiex_pcie 0000:01:00.0: last_event: 0b 00 0a 00 0b 00 0b 00 0a 00
[168814.517762] mwifiex_pcie 0000:01:00.0: data_sent=1 cmd_sent=1
[168814.523608] mwifiex_pcie 0000:01:00.0: ps_mode=1 ps_state=0
[168814.530956] mwifiex_pcie 0000:01:00.0: ===mwifiex driverinfo dump start===
[168814.538020] mwifiex_pcie 0000:01:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p195)
[168814.546585] mwifiex_pcie 0000:01:00.0: PCIE register dump start
[168814.552614] mwifiex_pcie 0000:01:00.0: pcie scratch register:
[168814.558478] mwifiex_pcie 0000:01:00.0: reg:0xcf0, value=0xfedcba00
[168814.558478] reg:0xcf8, value=0xfb0081
[168814.558478] reg:0xcfc, value=0x1959500
[168814.558478]
[168814.573892] mwifiex_pcie 0000:01:00.0: PCIE register dump end
[168814.579834] mwifiex_pcie 0000:01:00.0: ===mwifiex driverinfo dump end===
[168814.586656] mwifiex_pcie 0000:01:00.0: == mwifiex firmware dump start ==
[168853.431802] mwifiex_pcie 0000:01:00.0: == mwifiex firmware dump end ==
[168853.440374] mwifiex_pcie 0000:01:00.0: == mwifiex dump information to /sys/class/devcoredump start
[168853.449614] mwifiex_pcie 0000:01:00.0: == mwifiex dump information to /sys/class/devcoredump end
[168853.458550] mwifiex_pcie 0000:01:00.0: PREP_CMD: FW is in bad state
[168853.464971] mwifiex_pcie 0000:01:00.0: PREP_CMD: FW is in bad state
[168853.465041] mwifiex_pcie 0000:01:00.0: PREP_CMD: FW is in bad state
[168853.471490] mwifiex_pcie 0000:01:00.0: info: shutdown mwifiex…
[168853.477754] mwifiex_pcie 0000:01:00.0: deleting the crypto keys
[168853.484065] mwifiex_pcie 0000:01:00.0: rx_pending=0, tx_pending=2, cmd_pending=0
[168853.489915] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.503535] mwifiex_pcie 0000:01:00.0: deleting the crypto keys
[168853.509564] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.515696] mwifiex_pcie 0000:01:00.0: deleting the crypto keys
[168853.521721] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.527838] mwifiex_pcie 0000:01:00.0: deleting the crypto keys
[168853.533866] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.539982] mwifiex_pcie 0000:01:00.0: deleting the crypto keys
[168853.546002] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.552118] mwifiex_pcie 0000:01:00.0: deleting the crypto keys
[168853.563001] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.569152] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.575523] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.625615] mwifiex_pcie 0000:01:00.0: PREP_CMD: card is removed
[168853.968935] mwifiex_pcie 0000:01:00.0: info: dnld wifi firmware from 177740 bytes
[168856.076626] mwifiex_pcie 0000:01:00.0: info: FW download over, size 634228 bytes
[168856.837065] mwifiex_pcie 0000:01:00.0: WLAN FW is active
[168856.882217] mwifiex_pcie 0000:01:00.0: Unknown api_id: 3
[168856.887670] mwifiex_pcie 0000:01:00.0: Unknown api_id: 4
[168856.893119] mwifiex_pcie 0000:01:00.0: Unknown GET_HW_SPEC TLV type: 0x217
[168856.916107] mwifiex_pcie 0000:01:00.0: info: MWIFIEX VERSION: mwifiex 1.0 (16.68.1.p195)
[168856.924410] mwifiex_pcie 0000:01:00.0: driver_version = mwifiex 1.0 (16.68.1.p195)
In this case, it appears the driver was successfully downloaded, but that is not always the case. I have encountered incidents when the driver will “randomly” jettison, and it will not successfully download, and the wifi then reads as being in a bad state. The only solution at that point that I’ve found is to do a power cycle.
Obviously, this kicks the SOM off the network, which can’t happen for our application, and I’m not sure why this happens or how to prevent it from doing so. Any support / fixes are appreciated. Thanks!
v/r
grh
Also,
Over a 24-hr period, it appears to happen at random intervals, ranging from 2 minutes between driver dumps to as long as 5 hrs, 17 mins. This occurs on an otherwise stable system, continuously running, with no other intervention or system changes during this time on my part.
grh
Update on this: I’ve been able to achieve 99.99% uptime (68 secs of downtime over 168hrs) through the following:
1- iw dev mlan0 set power_save off
2- I have a script running every 30s that pings for the network and reconnects if down
Now, these results were on an isolated network, so we’ll see how it does in a “live” environment, but this suffices for our application, mwifiex driver issues notwithstanding.
