Multiple WAKE1_MICO#
We are using Dahlia board, imx8m DB 1GB wb it, and torizonCore 5.15.129-6.5.0+git.6f8fd49366db
Our system requires suspend-to-RAM most of the time and wake up by WAKE1_MICO# pin.
Is it possible to configure other GPIO pins using torizoncore-builder with custom DTS to have same functionality as WAKE1_MICO#?
Hi @peterz !
I will check internally if it is possible.
In the mean time, please share more details on why would you need to change this. It is important to be aware that if it is possible to change it, you will have an out-of-spec configuration related to Verdin Family Specification | Toradex Developer Center.
Hi @peterz!
For Verdin iMX8MM, it is possible to use another pin as the wake pin for the module. You just need to keep in mind the thread-off of doing so (see my previous message).
Could you share more details on why would you need to change it?
