Hi
I am analyzing the possibility to add an external SPI-NOR FLASH memory (model: w25q128, datasheet here) and use it like a normal disk with the help of MTD subsystem. This memory has support in the kernel source tree.
But I found out that MTD isn’t present in TorizonCore 5.3.0+build.7. I checked in linux-toradex.git - Linux kernel for Apalis, Colibri and Verdin modules, branches toradex-5.4.y, toradex_5.4-2.3.x-imx, and toradex_5.4-2.1.x-imx, and mtd subsystem is in the sources, but I guess it wasn’t compiled.
I think I need to add the whole /drivers/mtd folder to enable support for my FLASH memory, correct me if I’m wrong.
Which is the easiest way to get support for this? Do I have to recompile TorizonCore through Yocto?
Thank you,
Tomás
