to my Ixora board, I connected a PCIe device via an adapter cable. The device exposes some config registers on a PCIe BAR which I write to via /dev/mem driver. This had worked before on another brand TK1 board (Edit: confirmed, works with another brand TK1 board).
When I write something to the PCIe device which makes it engage in network data transfer, the serial console is flooded with this message: “MSELECT error detected! status=0x100”, until at some point the system decides to auto-reboot, as the CPU gets stalled by that.
Ah, and sometimes in between there will be this: “mmc0: Timeout waiting for hardware interrupt” + register dump of sdhci. (see attached quote at end of message) I’m not sure that message is in there every time, though.
(Weird, I’m not doing anything with mmc on that board, there is no card inserted in any slot)
I can, however, see, that the PCIe device does get those values that are written via the memory mapping (via a debug tool of the device connected to my PC) - so in principle, that works (not mapping wrong address ranges or anything).
I have found this thread, where that error line is mentioned - not much else in common with the overall failure, though, at least I can’t make much of it.
nvidia forum
Any idea what this could be about?
[ 691.063180] MSELECT error detected! status=0x100
[ 691.067927] mmc0: Timeout waiting for hardware interrupt.
[ 691.067931] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 691.067942] sdhci: Sys addr: 0x00000000 | Version: 0x00000303
[ 691.067948] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000000
[ 691.067954] sdhci: Argument: 0x00c4d3b0 | Trn mode: 0x00000023
[ 691.067960] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000031
[ 691.067966] sdhci: Power: 0x0000000b | Blk gap: 0x00000000
[ 691.067971] sdhci: Wake-up: 0x00000000 | Clock: 0x00000107
[ 691.067975] sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
[ 691.067980] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02fc000b
[ 691.067984] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 691.067990] sdhci: Caps: 0x376fd080 | Caps_1: 0x10002f77
[ 691.067995] sdhci: Cmd: 0x0000193a | Max curr: 0x00000000
[ 691.067998] sdhci: Host ctl2: 0x00003004
[ 691.068002] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0xae840030
[ 691.068004] sdhci: ===========================================
Edit:
lspci -vvv output with BSP 2.8b5 mainline:
lspci -vvv
00:01.0 PCI bridge: NVIDIA Corporation TegraK1 PCIe x4 Bridge (rev a1) (prog-if 00 [Normal decode])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 396
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000f000-00000fff [empty]
Memory behind bridge: 13000000-13bfffff [size=12M]
Prefetchable memory behind bridge: 0000000020000000-0000000020ffffff [size=16M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity+ SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation TegraK1 PCIe x4 Bridge
Capabilities: [48] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=1/2 Maskable- 64bit+
Address: 00000000ae3ab000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Mapping Address Base: 00000000fee00000
Capabilities: [80] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s, Exit Latency L0s <512ns
ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR-, OBFF Not Supported ARIFwd-
AtomicOpsCap: Routing- 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
AtomicOpsCtl: ReqEn- EgressBlck-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Kernel driver in use: pcieport
00:02.0 PCI bridge: NVIDIA Corporation TegraK1 PCIe x1 Bridge (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 397
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00001000-00001fff [size=4K]
Memory behind bridge: 13c00000-13cfffff [size=1M]
Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff [empty]
Capabilities: [40] Subsystem: NVIDIA Corporation TegraK1 PCIe x1 Bridge
Address: 00000000ae3ab000 Data: 0001
ExtTag+ RBE+
LnkCap: Port #1, Speed 5GT/s, Width x1, ASPM L0s, Exit Latency L0s <512ns
01:00.0 RAM memory: Xilinx Corporation Device 7011
Subsystem: Xilinx Corporation Device 0007
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 255
Region 0: Memory at 13000000 (64-bit, non-prefetchable) [disabled] [size=8M]
Region 2: Memory at 13800000 (64-bit, non-prefetchable) [disabled] [size=64K]
Region 4: Memory at 20000000 (64-bit, prefetchable) [disabled] [size=16M]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis-, LTR-, OBFF Not Supported
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
02:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Subsystem: Intel Corporation I210 Gigabit Network Connection
Interrupt: pin A routed to IRQ 22
Region 0: Memory at 13c00000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at 1000 [disabled] [size=32]
Region 3: Memory at 13c20000 (32-bit, non-prefetchable) [size=16K]
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [140 v1] Device Serial Number 00-a0-c9-ff-ff-00-00-00
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
Steering table in TPH capability structure
Kernel driver in use: igb
root@apalis-tk1-mainline:~# dmesg | grep BAR
[ 3.848236] pci 0000:00:01.0: BAR 9: assigned [mem 0x20000000-0x20ffffff 64bit pref]
[ 3.855986] pci 0000:00:01.0: BAR 8: assigned [mem 0x13000000-0x13bfffff]
[ 3.862797] pci 0000:00:02.0: BAR 8: assigned [mem 0x13c00000-0x13cfffff]
[ 3.869608] pci 0000:00:02.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 3.875714] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20ffffff 64bit pref]
[ 3.883506] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x137fffff 64bit]
[ 3.890864] pci 0000:01:00.0: BAR 2: assigned [mem 0x13800000-0x1380ffff 64bit]
[ 3.917797] pci 0000:02:00.0: BAR 0: assigned [mem 0x13c00000-0x13c1ffff]
[ 3.924594] pci 0000:02:00.0: BAR 3: assigned [mem 0x13c20000-0x13c23fff]
[ 3.931411] pci 0000:02:00.0: BAR 2: assigned [io 0x1000-0x101f]
