I’m using a Colibri imx8 with Torizon OS. I’m trying to write to a FAT32 pendrive from a container (Avalonia), but it doesn’t work because the system mounts it with root privileges.
I’ve seen some possible solutions, but none of them helped. How can I fix this problem?
I would like it to work dynamically for every new pendrive inserted.
Hello!
When working with USB device mounting on Torizon OS, there are several methods to ensure proper permissions and functionality:
Static USB Device Mounting: You can configure an entry in /etc/fstab to mount a USB device with specific permissions for the torizon user (uid=1000). Here is an example:
/dev/sda1 /media/card auto defaults,sync,auto,nofail,uid=1000,gid=1000 0 0
This setup ensures that the USB device is mounted with the correct user permissions, allowing seamless access.
Container Access: If you need to access the USB device from within a container, configure bind mount propagation in your docker-compose file as follows:
This configuration allows the container to see new mounts dynamically.
Avoiding Permission Issues: When mounting volumes for container access, avoid using paths under /home/torizon/app/ to prevent permission conflicts. Instead, opt for alternative paths like /applogs or other root-level directories.
For dynamic USB device mounting, ensure the following:
The bind mount is configured with shared propagation so that new mounts are visible within the container.
The fstab entry includes the nofail option to handle scenarios where the device might be absent without causing errors.
After making changes to your mount configurations, remember to reboot the system for the changes to take effect.
I hope this helps you manage USB device mounting effectively on Torizon OS.
USB devices can be swapped while the container is running, fstab doesn’t handle this, only at boot time. I need a dynamic solution. The rule written in /etc/udev/rules.d doesn’t want to work either.
Wait, are you saying entries in /etc/fstab only work on boot for you? That doesn’t seem correct, I know in my own experience /etc/fstab entries work for removable media that are attached/removed while the device is running. This is what other customers experience as well when I recommend trying this method. Do you not observe this yourself, if not what do you observe?
