Hi
I am trying to access Windows/OSX shared folders from my Apalis iMX6 V2.6.
I am attempting to follow tutorial on
http://developer.toradex.com/knowledge-base/smb-support
Can you please expand on section that says
“Please note that the cifs-utils package is unfortunately not currently available in any Ångström feed and needs to be built as per our OpenEmbedded instructions.”
Which OpenEmbedded instructions are you referencing? I have built my open embedded image following
http://developer.toradex.com/knowledge-base/board-support-package/openembedded-(core)
and have successfully loaded it onto my SOM. My system shows
root@apalis_imx6:~# cat /proc/filesystems | grep cifs
nodev cifs
I have samba running on my apalis and can successfully access the shared apalis samba folders on other linux/osx/windows systems.
Attempting mount -t cifs fails with
root@apalis_imx6:~# mount -t cifs *.*.*.*:/SharedFolder /srv/nfs/shared
mount: wrong fs type, bad option, bad superblock on *.*.*.*:/SharedFolder,
missing codepage or helper program, or other error
(for several filesystems (e.g. nfs, cifs) you might
need a /sbin/mount.<type> helper program)
In some cases useful info is found in syslog - try
dmesg | tail or so.
What might I be missing in acquiring smbmount or mount.cifs commands on apalis imx6 system?
Thanks!
