Hello! Thank you for your detailed description. This issue is related to a recent migration in the Torizon IDE Extension from PowerShell scripts to Python/Xonsh scripts, which brings new dependencies like the Python module torizon_templates_utils. The error you see indicates that your extension setup is missing some of these updated components.
To resolve this, please do the following steps:
Install the Pre-release Version of the Extension
The latest templates and corresponding dependencies are available in the pre-release version of the Torizon IDE Extension. Please install or switch to the pre-release version by following the instructions here:
Pre-Release Torizon OS 7 Support / VS Code / Torizon Templates / Development Tools -
Configure VS Code to Use the ‘dev’ Branch for Templates
Update your VS Code global settings (open Command Palette > Preferences: Open Settings (JSON)) and add the following lines:
"torizon.templatesRepo": "https://github.com/torizon/vscode-torizon-templates", "torizon.templatesBranch": "dev", "torizon.templatesTag": "dev",This ensures you’re using the development branch, which includes the necessary Python/Xonsh dependencies.
Restart VS Code
Close and reopen VS Code to ensure all changes take effect.
These steps should pull the latest scripts and dependencies, resolving the missing torizon_templates_utils error and allowing your project tasks (like run-torizon-binfmt and check-deps) to run correctly.
For further reference, please see:
