ModuleNotFoundError: No module named '_sqlite3'
I was trying to build embedded linux image BSP V2.8.6b and following the link:
https://developer.toradex.com/knowledge-base/board-support-package/openembedded-(core)
But when I was trying to bitbake I’m having the following error:
bmit@bmit-X200MA:~/yocto/oe-core/build$ bitbake -k angstrom-lxde-image
  File "/home/bmit/yocto/oe-core/layers/openembedded-core/bitbake/bin/bitbake", line 31, in
    import bb
  File "/home/bmit/yocto/oe-core/layers/openembedded-core/bitbake/lib/bb/__init__.py", line 79, in
    from bb import fetch2 as fetch
  File "/home/bmit/yocto/oe-core/layers/openembedded-core/bitbake/lib/bb/fetch2/__init__.py", line 39, in
    import bb.persist_data, bb.utils
  File "/home/bmit/yocto/oe-core/layers/openembedded-core/bitbake/lib/bb/persist_data.py", line 31, in
    import sqlite3
  File "/usr/local/lib/python3.6/sqlite3/__init__.py", line 23, in
    from sqlite3.dbapi2 import *
  File "/usr/local/lib/python3.6/sqlite3/dbapi2.py", line 27, in
    from _sqlite3 import *
Hi @sonicmaster
Which Linux Distribution ( uname -a ) are you using on the module?
Did you install all the prerequisites as described here?
You could try to install following package on your build host: libsqlite3-dev
