I got the error message above in starting my QML application. I used console-trdx-image to create the image of my rootfs. I added the following lines to local.conf to enable Qt (local.conf contains qtdeclarative and qtquickcontrols)
IMAGE_INSTALL_append = " \
qtbase \
qtbase-fonts \
qtbase-plugins \
qtdeclarative \
qt3d \
qtgraphicaleffects \
qtconnectivity \
qtquickcontrols \
qtquick1 \
qtimageformats \
qtenginio \
qtlocation \
qtmultimedia \
qtsensors \
qtscript \
qtserialport \
qtsvg \
qtcanvas3d \
qttranslations \
qtsystems \
qtxmlpatterns \
qttools \
DISTRO_FEATURES_remove = "x11 wayland"
IMAGE_INSTALL_remove = "eglinfo-x11"
ACCEPT_FSL_EULA = "1"
The qml-files and code to use QtQuick controls normally resides in the the folder /usr/libqt5/qmlQtQuick/Controls. But there exists no folder Controls at all.If I search the QtQuick control Slider.qml ( find . -name Slider.qml) at the starting point of rootfs there is nothing found at all. Normally the folder Controls should contain about 20 qml files and the lib libqtquickcontrolsplugin.so.
Eric Schall
