I am using Colibri iMX7d 1Gb eMMC V1.1A with Colibri evaluation board V3.2b running embedded linux v2.8b6 from yocto. I have changed the device tree and kernel using
ums 0 mmc 0
during u-boot. I have build the kernel from source as described here. The problem is
modprobe imx_rpmsg_tty
was working fine but after changing the kernel,while modprobe, I am getting the following error
modprobe: FATAL: Module imx_rpmsg_tty not found in directory /lib/modules/4.9.166-00001-g6bd85ffba9f2-dirty
The modprobe is looking for kernel-modules in a directory that doesn’t exist. The name of the folder that I have in /lib/modules is 4.9.166-2.8.6+gd899927728be. Is this due to kernel mismatch? Is it possible to change the directory that modprobe looks for the kernel-modules?
Thanks and Regards,
Nishanth
