I am unable to get my docker image to load at start up of torizon core build, by adding it to /var/sota/storage/docker-compose/docker-compose.yml file. I am able to do a docker run of the image at the ssh command line though when trying to get it to auto load a boot up it does not load.
Also, if there are other standard images (e.g. torizon/weston-vivante, portainer/portainer-ce) they also do not load, I expect indicating that my added qse image is interfering with the docker-compose image running process. (note: sha256 value shorted with … added in middle just for this example)
Any help/insight would be appreciated on this approach or other approaches. - Thanks!
The torizon core is a custom build based on “torizon-core-docker-colibri-imx8x-Tezi_5.4.0+build.10.tar”
So what happens exactly when you try to auto load this container on boot? Is there an error, or just nothing happens?
We use a systemd service that auto-runs any docker-compose.yml file located at /var/sota/storage/docker-compose at boot time.
Could you run systemctl status docker-compose and also journalctl -f -u docker-compose. These commands should return the logs for this systemd service. This will hopefully tell us what’s going on, or whether the service is even running properly.
Looks like the docker-compose.service is running ok (output at end of message).
I have started just running a docker-compose.yml file in the home torizon directory to isolate the problem in the running of the container as a docker-compose.yml file, using “docker-compose up”. when I do this the container runs exits(0) or resets periodically if reset is selected in docker-compose file options.
Something between the docker run command line (works) and translation to docker-compose.yml (doesn’t work) seems to be the issue at this point. Using the docker-compose up and local docker-compose.yml file the image does not persists or just resets after run. I will continue to try to find the working docker-compose.yml commands, once again any input would be appreciated, thanks!
colibri-imx8x-06900091:~$ systemctl status docker-compose
● docker-compose.service - Docker Compose service with docker compose
Loaded: loaded (/usr/lib/systemd/system/docker-compose.service; enabled; vendor preset: enabled)
Active: active (exited) since Wed 2021-12-22 15:17:56 EST; 3min 59s ago
Process: 851 ExecStart=/usr/bin/docker-compose -p torizon up -d --remove-orphans (code=exited, status=0/SUCCESS)
Process: 852 ExecStartPost=/usr/bin/rm -f /tmp/recovery-attempt.txt (code=exited, status=0/SUCCESS)
Main PID: 851 (code=exited, status=0/SUCCESS)
Dec 22 15:17:56 colibri-imx8x-06900091 systemd[1]: Starting Docker Compose service with docker compose…
Dec 22 15:17:56 colibri-imx8x-06900091 systemd[1]: Started Docker Compose service with docker compose.
Dec 22 15:18:00 colibri-imx8x-06900091 docker-compose[851]: Creating network “torizon_default” with the default driver
Dec 22 15:18:00 colibri-imx8x-06900091 docker-compose[851]: Creating torizon_qse_1 …
Dec 22 15:18:03 colibri-imx8x-06900091 docker-compose[851]: [45B blob data]
colibri-imx8x-06900091:~$ journalctl -f -u docker-compose
– Logs begin at Wed 2021-12-22 15:17:45 EST. –
An update … I have my qse app running now with the docker-compose service. Finding the tricks to make it run using a local file and docker-compose up to run it was the diagnostic tool that helped me narrow down the issue I was having. Thanks for your help Jeremias, happy holidays : )
