Hello!
I’m using the latest BSP with QT 5.9 in my projects and it almost works fine except for the QT-GStreamer. I have a lot of memory problems in this version.
However, I tested the demo version of QT 5.11 and everything went well.
So after that, I tried to change the QT recipes from the last BSP, but there is always a problem that prevents the generation of images.
How could I correctly change the QT recipes to generate an image with the latest stable QT and the last stable GStreamer?
Regards!
Ps: GStreamer messages (from Kernel). After some fail repetitions, eth0 goes down.
[ 47.129152] WARNING: CPU: 1 PID: 592 at /media/dock/opt/yocto/oe-core/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/mm/page_alloc.c:7393 free_contig_range+0x94/0x98
[ 47.144676] 375 pages are still in use!
[ 47.148547] Modules linked in: bluetooth(O) compat(O) usb_f_rndis u_ether hid_multitouch pn5xx_i2c libcomposite configfs galcore(O)
[ 47.160545] CPU: 1 PID: 592 Comm: QSGRenderThread Tainted: G O 4.9.87-2.8.3+g07d40f6f #9
[ 47.169765] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 47.176292] Backtrace:
[ 47.178771] [<8010ba5c>] (dump_backtrace) from [<8010bd34>] (show_stack+0x18/0x1c)
[ 47.186344] r7:00000009 r6:600a0013 r5:00000000 r4:80c1a9b0
[ 47.192013] [<8010bd1c>] (show_stack) from [<803f79e4>] (dump_stack+0x90/0xa4)
[ 47.199245] [<803f7954>] (dump_stack) from [<80124d14>] (__warn+0xec/0x104)
[ 47.206209] r7:00000009 r6:809101a0 r5:00000000 r4:8d487db0
[ 47.211875] [<80124c28>] (__warn) from [<80124d6c>] (warn_slowpath_fmt+0x40/0x48)
[ 47.219362] r9:8d486000 r8:80c914c0 r7:80c06344 r6:000242b6 r5:00000177 r4:80910978
[ 47.227113] [<80124d30>] (warn_slowpath_fmt) from [<801c8c70>] (free_contig_range+0x94/0x98)
[ 47.235551] r3:00000177 r2:80910978
[ 47.239126] r4:000242b6
[ 47.241669] [<801c8bdc>] (free_contig_range) from [<80204b84>] (cma_release+0x88/0xa4)
[ 47.249589] r9:8d486000 r8:6e503944 r7:801140e8 r6:00000000 r5:00024100 r4:80c92204
[ 47.257342] [<80204afc>] (cma_release) from [<804e5624>] (dma_release_from_contiguous+0x38/0x3c)
[ 47.266126] r5:001b6000 r4:8fdec000
[ 47.269714] [<804e55ec>] (dma_release_from_contiguous) from [<801136fc>] (cma_allocator_free+0x58/0x7c)
[ 47.279113] [<801136a4>] (cma_allocator_free) from [<801140d4>] (__arm_dma_free.constprop.2+0x124/0x138)
[ 47.288594] r7:801140e8 r6:24100000 r5:94100000 r4:8d3fdfc0
[ 47.294259] [<80113fb0>] (__arm_dma_free.constprop.2) from [<80114104>] (arm_dma_free+0x1c/0x24)
[ 47.303044] r5:94100000 r4:001b6000
[ 47.306632] [<801140e8>] (arm_dma_free) from [<8062ac7c>] (vpu_free_dma_buffer+0x94/0xb4)
[ 47.314815] [<8062abe8>] (vpu_free_dma_buffer) from [<8062c134>] (vpu_ioctl+0x854/0xaec)
[ 47.322909] r7:0000001f r6:8d158600 r5:00000051 r4:6e503944
[ 47.328573] [<8062b8e0>] (vpu_ioctl) from [<8021aa94>] (do_vfs_ioctl+0xa8/0x8e8)
[ 47.335973] r8:6e503944 r7:0000001f r6:8d158600 r5:8c4e0c70 r4:6e503944
[ 47.342678] [<8021a9ec>] (do_vfs_ioctl) from [<8021b310>] (SyS_ioctl+0x3c/0x60)
[ 47.349991] r10:00000000 r9:8d486000 r8:6e503944 r7:00005601 r6:0000001f r5:8d158600
[ 47.357819] r4:8d158601
[ 47.360360] [<8021b2d4>] (SyS_ioctl) from [<80107d20>] (ret_fast_syscall+0x0/0x48)
[ 47.367933] r9:8d486000 r8:80107ee4 r7:00000036 r6:00005601 r5:678ee398 r4:6e503944
[ 47.375733] ---[ end trace 013a858af82ba851 ]---
[ 47.380678] ------------[ cut here ]------------
[ 47.385321] WARNING: CPU: 1 PID: 592 at /media/dock/opt/yocto/oe-core/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/mm/page_alloc.c:7393 free_contig_range+0x94/0x98
[ 47.400840] 375 pages are still in use!
[ 47.404694] Modules linked in: bluetooth(O) compat(O) usb_f_rndis u_ether hid_multitouch pn5xx_i2c libcomposite configfs galcore(O)
[ 47.416700] CPU: 1 PID: 592 Comm: QSGRenderThread Tainted: G W O 4.9.87-2.8.3+g07d40f6f #9
[ 47.425921] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 47.432448] Backtrace:
[ 47.434927] [<8010ba5c>] (dump_backtrace) from [<8010bd34>] (show_stack+0x18/0x1c)
[ 47.442501] r7:00000009 r6:600a0013 r5:00000000 r4:80c1a9b0
[ 47.448169] [<8010bd1c>] (show_stack) from [<803f79e4>] (dump_stack+0x90/0xa4)
[ 47.455404] [<803f7954>] (dump_stack) from [<80124d14>] (__warn+0xec/0x104)
[ 47.462367] r7:00000009 r6:809101a0 r5:00000000 r4:8d487db0
[ 47.468034] [<80124c28>] (__warn) from [<80124d6c>] (warn_slowpath_fmt+0x40/0x48)
[ 47.475520] r9:8d486000 r8:80c914c0 r7:80c06344 r6:000244b6 r5:00000177 r4:80910978
[ 47.483272] [<80124d30>] (warn_slowpath_fmt) from [<801c8c70>] (free_contig_range+0x94/0x98)
[ 47.491710] r3:00000177 r2:80910978
[ 47.495285] r4:000244b6
[ 47.497830] [<801c8bdc>] (free_contig_range) from [<80204b84>] (cma_release+0x88/0xa4)
[ 47.505751] r9:8d486000 r8:6e71e6e4 r7:801140e8 r6:00000000 r5:00024300 r4:80c92204
[ 47.513500] [<80204afc>] (cma_release) from [<804e5624>] (dma_release_from_contiguous+0x38/0x3c)
[ 47.522287] r5:001b6000 r4:8fdf0000
[ 47.525872] [<804e55ec>] (dma_release_from_contiguous) from [<801136fc>] (cma_allocator_free+0x58/0x7c)
[ 47.535272] [<801136a4>] (cma_allocator_free) from [<801140d4>] (__arm_dma_free.constprop.2+0x124/0x138)
[ 47.544754] r7:801140e8 r6:24300000 r5:94300000 r4:8d3fd9c0
[ 47.550419] [<80113fb0>] (__arm_dma_free.constprop.2) from [<80114104>] (arm_dma_free+0x1c/0x24)
[ 47.559204] r5:94300000 r4:001b6000
[ 47.562789] [<801140e8>] (arm_dma_free) from [<8062ac7c>] (vpu_free_dma_buffer+0x94/0xb4)
[ 47.570971] [<8062abe8>] (vpu_free_dma_buffer) from [<8062c134>] (vpu_ioctl+0x854/0xaec)
[ 47.579064] r7:0000001f r6:8d158600 r5:00000051 r4:6e71e6e4
[ 47.584729] [<8062b8e0>] (vpu_ioctl) from [<8021aa94>] (do_vfs_ioctl+0xa8/0x8e8)
[ 47.592128] r8:6e71e6e4 r7:0000001f r6:8d158600 r5:8c4e0c70 r4:6e71e6e4
[ 47.598834] [<8021a9ec>] (do_vfs_ioctl) from [<8021b310>] (SyS_ioctl+0x3c/0x60)
[ 47.606147] r10:00000000 r9:8d486000 r8:6e71e6e4 r7:00005601 r6:0000001f r5:8d158600
[ 47.613976] r4:8d158601
[ 47.616519] [<8021b2d4>] (SyS_ioctl) from [<80107d20>] (ret_fast_syscall+0x0/0x48)
[ 47.624095] r9:8d486000 r8:80107ee4 r7:00000036 r6:00005601 r5:678ee398 r4:6e71e6e4
[ 47.631912] ---[ end trace 013a858af82ba852 ]---
[ 47.636937] ------------[ cut here ]------------
[ 47.641641] WARNING: CPU: 1 PID: 592 at /media/dock/opt/yocto/oe-core/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/mm/page_alloc.c:7393 free_contig_range+0x94/0x98
[ 47.657158] 375 pages are still in use!
[ 47.661021] Modules linked in: bluetooth(O) compat(O) usb_f_rndis u_ether hid_multitouch pn5xx_i2c libcomposite configfs galcore(O)
[ 47.673012] CPU: 1 PID: 592 Comm: QSGRenderThread Tainted: G W O 4.9.87-2.8.3+g07d40f6f #9
[ 47.682232] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 47.688759] Backtrace:
[ 47.691237] [<8010ba5c>] (dump_backtrace) from [<8010bd34>] (show_stack+0x18/0x1c)
[ 47.698810] r7:00000009 r6:600a0013 r5:00000000 r4:80c1a9b0
[ 47.704479] [<8010bd1c>] (show_stack) from [<803f79e4>] (dump_stack+0x90/0xa4)
[ 47.711711] [<803f7954>] (dump_stack) from [<80124d14>] (__warn+0xec/0x104)
[ 47.718675] r7:00000009 r6:809101a0 r5:00000000 r4:8d487db0
[ 47.724341] [<80124c28>] (__warn) from [<80124d6c>] (warn_slowpath_fmt+0x40/0x48)
[ 47.731828] r9:8d486000 r8:80c914c0 r7:80c06344 r6:000246b6 r5:00000177 r4:80910978
[ 47.739581] [<80124d30>] (warn_slowpath_fmt) from [<801c8c70>] (free_contig_range+0x94/0x98)
[ 47.748020] r3:00000177 r2:80910978
[ 47.751595] r4:000246b6
[ 47.754138] [<801c8bdc>] (free_contig_range) from [<80204b84>] (cma_release+0x88/0xa4)
[ 47.762058] r9:8d486000 r8:6e5ed2e4 r7:801140e8 r6:00000000 r5:00024500 r4:80c92204
[ 47.769809] [<80204afc>] (cma_release) from [<804e5624>] (dma_release_from_contiguous+0x38/0x3c)
[ 47.778594] r5:001b6000 r4:8fdf4000
[ 47.782181] [<804e55ec>] (dma_release_from_contiguous) from [<801136fc>] (cma_allocator_free+0x58/0x7c)
[ 47.791580] [<801136a4>] (cma_allocator_free) from [<801140d4>] (__arm_dma_free.constprop.2+0x124/0x138)
[ 47.801061] r7:801140e8 r6:24500000 r5:94500000 r4:8d3fde80
[ 47.806726] [<80113fb0>] (__arm_dma_free.constprop.2) from [<80114104>] (arm_dma_free+0x1c/0x24)
[ 47.815511] r5:94500000 r4:001b6000
[ 47.819097] [<801140e8>] (arm_dma_free) from [<8062ac7c>] (vpu_free_dma_buffer+0x94/0xb4)
[ 47.827280] [<8062abe8>] (vpu_free_dma_buffer) from [<8062c134>] (vpu_ioctl+0x854/0xaec)
[ 47.835374] r7:0000001f r6:8d158600 r5:00000051 r4:6e5ed2e4
[ 47.841039] [<8062b8e0>] (vpu_ioctl) from [<8021aa94>] (do_vfs_ioctl+0xa8/0x8e8)
[ 47.848437] r8:6e5ed2e4 r7:0000001f r6:8d158600 r5:8c4e0c70 r4:6e5ed2e4
[ 47.855141] [<8021a9ec>] (do_vfs_ioctl) from [<8021b310>] (SyS_ioctl+0x3c/0x60)
[ 47.862453] r10:00000000 r9:8d486000 r8:6e5ed2e4 r7:00005601 r6:0000001f r5:8d158600
[ 47.870281] r4:8d158601
[ 47.872822] [<8021b2d4>] (SyS_ioctl) from [<80107d20>] (ret_fast_syscall+0x0/0x48)
[ 47.880395] r9:8d486000 r8:80107ee4 r7:00000036 r6:00005601 r5:678ee398 r4:6e5ed2e4
[ 47.888193] ---[ end trace 013a858af82ba853 ]---
[ 47.893061] ------------[ cut here ]------------
[ 47.897703] WARNING: CPU: 1 PID: 592 at /media/dock/opt/yocto/oe-core/build/tmp-glibc/work-shared/colibri-imx6/kernel-source/mm/page_alloc.c:7393 free_contig_range+0x94/0x98
[ 47.913224] 375 pages are still in use!
[ 47.917064] Modules linked in: bluetooth(O) compat(O) usb_f_rndis u_ether hid_multitouch pn5xx_i2c libcomposite configfs galcore(O)
[ 47.929076] CPU: 1 PID: 592 Comm: QSGRenderThread Tainted: G W O 4.9.87-2.8.3+g07d40f6f #9
[ 47.938297] Hardware name: Freescale i.MX6 Quad/DualLite (Device Tree)
[ 47.944825] Backtrace:
[ 47.947300] [<8010ba5c>] (dump_backtrace) from [<8010bd34>] (show_stack+0x18/0x1c)
[ 47.954873] r7:00000009 r6:600a0013 r5:00000000 r4:80c1a9b0
[ 47.960543] [<8010bd1c>] (show_stack) from [<803f79e4>] (dump_stack+0x90/0xa4)
[ 47.967776] [<803f7954>] (dump_stack) from [<80124d14>] (__warn+0xec/0x104)
[ 47.974741] r7:00000009 r6:809101a0 r5:00000000 r4:8d487db0
[ 47.980407] [<80124c28>] (__warn) from [<80124d6c>] (warn_slowpath_fmt+0x40/0x48)
[ 47.987892] r9:8d486000 r8:80c914c0 r7:80c06344 r6:000248b6 r5:00000177 r4:80910978
[ 47.995643] [<80124d30>] (warn_slowpath_fmt) from [<801c8c70>] (free_contig_range+0x94/0x98)
[ 48.004081] r3:00000177 r2:80910978
[ 48.007657] r4:000248b6
[ 48.010201] [<801c8bdc>] (free_contig_range) from [<80204b84>] (cma_release+0x88/0xa4)
[ 48.018123] r9:8d486000 r8:6e71e364 r7:801140e8 r6:00000000 r5:00024700 r4:80c92204
[ 48.025874] [<80204afc>] (cma_release) from [<804e5624>] (dma_release_from_contiguous+0x38/0x3c)
[ 48.034659] r5:001b6000 r4:8fdf8000
[ 48.038243] [<804e55ec>] (dma_release_from_contiguous) from [<801136fc>] (cma_allocator_free+0x58/0x7c)
[ 48.047642] [<801136a4>] (cma_allocator_free) from [<801140d4>] (__arm_dma_free.constprop.2+0x124/0x138)
[ 48.057124] r7:801140e8 r6:24700000 r5:94700000 r4:8d3fd440
[ 48.062788] [<80113fb0>] (__arm_dma_free.constprop.2) from [<80114104>] (arm_dma_free+0x1c/0x24)
[ 48.071573] r5:94700000 r4:001b6000
[ 48.075157] [<801140e8>] (arm_dma_free) from [<8062ac7c>] (vpu_free_dma_buffer+0x94/0xb4)
[ 48.083339] [<8062abe8>] (vpu_free_dma_buffer) from [<8062c134>] (vpu_ioctl+0x854/0xaec)
[ 48.091432] r7:0000001f r6:8d158600 r5:00000051 r4:6e71e364
[ 48.097096] [<8062b8e0>] (vpu_ioctl) from [<8021aa94>] (do_vfs_ioctl+0xa8/0x8e8)
[ 48.104495] r8:6e71e364 r7:0000001f r6:8d158600 r5:8c4e0c70 r4:6e71e364
[ 48.111199] [<8021a9ec>] (do_vfs_ioctl) from [<8021b310>] (SyS_ioctl+0x3c/0x60)
[ 48.118513] r10:00000000 r9:8d486000 r8:6e71e364 r7:00005601 r6:0000001f r5:8d158600
[ 48.126341] r4:8d158601
[ 48.128881] [<8021b2d4>] (SyS_ioctl) from [<80107d20>] (ret_fast_syscall+0x0/0x48)
[ 48.136453] r9:8d486000 r8:80107ee4 r7:00000036 r6:00005601 r5:678ee398 r4:6e71e364
[ 48.144260] ---[ end trace 013a858af82ba854 ]---
