Following tutorial OpenEmbedded (core) using version 3.0 I was able to built console-tdx-image. Than I wanted to add Qt into it, so I followed the How to set up Qt Creator to cross compile for embedded Linux tutorial choosing Build with OpenEmbedded Layers.
In this process I added into build/conf/local.conf
IMAGE_INSTALL_append = " qtbase qtdeclarative qtimageformats qtmultimedia qtquickcontrols2 qtquickcontrols "
After that I run bitbake -k console-tdx-image and bitbake -k console-tdx-image -c populate_sdk. The built SDK was installed successfully but it is missing the crucial qmake. Nothing in sysroots/x86_64-tdxsdk-linux/usr/bin/qt5/qmake or in sysroots/x86_64-tdxsdk-linux/usr/bin/qmake.
What I’m missing?
HI @cicicok
To include the Qt Tools in your SDK, either you need to make lxqt-image
or add inherit populate_sdk_qt5
in your image recipe as explained here.
For everybody who will be struggling as I, you can use this tutorial (from 06 Jan 2020), but there are few changes. There is no qtquick1
in 3.0 so just leave it.
Add to ~/oe-core/build/conf/local.conf this:
The second step needs to be done before starting the bitbake process, as mentioned you need to add inherit populate_sdk_qt5
to the image you are building. I’m building the console-tdx-image, so I added it its image recipe ~/oe-core/layers/meta-toradex-demos/recipes-images/images/console-tdx-image.bb
Run bitbake and thats all.
P.S. qmake will be in this version no longer located at /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/qt5/qmake but at /opt/tdx-x11/2.6.4/sysroots/x86_64-tdxsdk-linux/usr/bin/qmake
HI @cicicok
Thanks for your valuable input.
