Mini PCI SSD Storage for Verdin iMX8M Plus
Hello ,
We would like to buy The iMX8M Plus Quad 4GB IT Verdin Module.
We need to record CSI video camera and so, we have to use SSD Storage Disk
about 128 gb or above,Please suggest on how to achieve this!!
There is a “Mini PCIe” disk drive for your sugestion carrier board like Dahlia??
We have found SQF-CMS 710 PCIe Gen3 x2 SSD(link).
Can we use that item with Verdin iMX8M Plus and Dahlia??
There is hardware support on the carrier board and the SOM??
Regards
Hami
do have someone any ideas?
Thanks in advance
Hi @hhami !
We have the Peripheral Devices database, but there is no Mini PCI SSD listed there.
We do not keep information about support for external devices as it also depends on the Linux Kernel itself. What you can do is check if the device you would like to use has a compatible driver on Linux Kernel. Maybe the vendor of the device can help you with this information.
Also, I asked internally if someone has a recommendation for Mini PCI SSD Storage. I will let you know if someone recommends something.
Hi @hhami !
After asking internally, some SSD PCIe devices popped up:
Hopefully, they are helpful to you.
