Hello! Thank you for providing the details of your issues during the migration from Rocko to Scarthgap. Let’s address your U-Boot and kernel problems step by step.
1. U-Boot: “MMC Device 0 not found” & “MISSING TORADEX CONFIG BLOCK”
Root Cause:
These messages mean that U-Boot is unable to detect the eMMC storage, so it cannot read the environment or the Toradex config block (which holds crucial information like MAC address).
Recommended Checks:
eMMC Hardware Boot Area Configuration:
Since BSP V2.5b2, U-Boot and the configuration block are stored in the primary eMMC hardware boot area partition (/dev/mmcblk0boot0).
You should ensure the boot partitions are enabled and configured correctly. From the U-Boot prompt, try:mmc list mmc dev 0 mmc partIf nothing appears or errors persist, U-Boot may not be recognizing the eMMC.
Verify eMMC Boot Partition Settings:
Check boot partition configurations:mmc bootbus 0 mmc partconf 0More details here:
Booting from eMMC Hardware Boot Area Partitions -
Config Block Migration:
If you migrated a module with the old layout, make sure the config block was properly carried over to the correct location. -
Power Failures or Corruption:
Sudden power-offs during migration might have left the eMMC in a corrupted state, leading to detection failures.
Related Community Discussion
2. Kernel: “Failed to start Ethtool configuration for eth0”
This error likely results from a missing MAC address or interface configuration. Since the MAC is normally loaded from the config block on eMMC, your U-Boot issue is the root cause. Once U-Boot can see the config block, the MAC address will be correct, and this kernel error should disappear.
Summary of Steps to Resolve:
- From U-Boot, verify and list the MMC devices. Test access to boot partitions as above.
- If eMMC is not visible, review your migration steps for moving the config block and ensure correct U-Boot environment settings.
- Check power and eMMC connections if the issue persists after the above.
- Once U-Boot detects eMMC and the config block, the Ethtool startup issue in Linux should be resolved automatically.
Extra Links for Reference:
Please try the above and let me know what further details you find after running the suggested U-Boot commands. If you have relevant boot logs or screenshots, sharing those can help narrow down the root cause.
