Failed to load OS image
Last week, one of our customer faced to 3 Colibri SOM broken in same week-end.
After, first analysis, we identified an error when bootloader try to extract OS image.
Following message is display by the console.
. . Error extracting data B9ffOOOO - 39171 - 80760000.
ERROR: Failed to load OS image from SD,'FNC.
INFO: OEMRe ortError Reason Oxfffffffa
Do you have any idea on what might have happened?
Colibri IMX6S V1.1Y
Thanks for your help,
The error message you’re encountering suggests that the bootloader on your Colibri iMX6S V1.1Y modules is having trouble extracting the OS image from the SD card. Here are some potential causes and steps you can take to resolve the issue:
  1. Corrupted OS Image: Verify that the OS image on the SD card is not corrupted. You can do this by checking the checksum of the image file and comparing it with the original.
  2. Faulty SD Card: The SD card might be faulty. Try using a different SD card to see if the problem persists.
  3. Incompatible OS Image: Ensure that the OS image is compatible with your Colibri iMX6S V1.1Y module. Different hardware revisions may require specific images.
  4. Bootloader Configuration: Check the bootloader configuration to ensure it is correctly set up to load the OS image from the SD card. Incorrect settings can prevent the bootloader from accessing the image.
  5. Software Updates: Make sure both the bootloader and the OS image are up to date. Updates can sometimes resolve compatibility issues or bugs that might cause such errors.
By systematically checking these areas, you should be able to identify the root cause of the problem. If the issue persists, further investigation into the specific error codes and logs during the boot process might be necessary.
I hope this helps you resolve the issue.
Toradex AI Assistant
Toradex Easy Installer from BSP5 to BSP6 using pendrive.
Colibri suddenly started in this state (maybe after a power failure).
No firmware upgrade perform before issue.
Hi @mblac7 ,
Can you provide the complete Serial Log including the Bootloader version?
Is the log exactly the same on all 3 modules?
It looks like the output is somehow corrupted.. maybe not captured properly from serial port? Or is it really like that?
From the little i can see it looks like a Error while reading from the internal eMMC, but it would be very very strange if it’s the same address on all 3 modules.
Here is the output of the 3 SOM
Hi @germano.tx
I uploaded bootloader output snapshots (see above) where MMC corruption is mentioned.
Hi @mblac7,
Sorry for the late answer i was on leave and nobody else could answer this.
From what you sent it looks like the 3 modules all have a corrupted Image, but all 3 at different locations. You say there was no Image update before the failure.. that’s really strange. Maybe something else overwrote those parts of the image?
I’m not sure if those 3 modules are still is this state, but if so you can send back those modules to us for analysis if you can spare them.
