Meta-updater integration for Yocto BSP5 build for Colibri iMX6ULL
Hello!
I have done a BSP5 build with yocto and succesfully integrated our custom company layer for Colibri iMX6ULL. I’m using dunfell branch.
repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
Now, what I am trying to achieve is to integrate meta-updater layer so I can have OStree and can make OTA updates. I don’t need all Torizon features such as docker. I understand that iMX6ULL is not fully supported by Torizon Ecosystem.
The strategy I’m using is to look what is being made on meta-toradex-torizon, all patches, bbappends and etc, and trying to replicate that on my BSP5 build.
I was able to build an image tdx-reference-minimal-image without errors and flash it to imx6ull via EasyInstaller, but when I try to boot the image I get the error:
ERROR: Did not find a cmdline Flattened Device Tree
And it is stuck at “Starting kernel …”
So my question is what may I be missing on integrating meta-updater with BSP5? Maybe something related to device tree or u-boot that TorizonCore does and I’m not doing?
If needed, I can give more information such as my u-boot environment variables, boot messages and etc.
Hi @giobauermeister.
Unfortunately, the integration of OSTree is not easy nor simple.
We suggest you to use as a starting point the TorizonCore, and you can use TorizonCore-Lite as a reference.
Please let me know if that helped.
André Curvello
Hi giobauermeister
Have you integrate meta-updater to your BSP5 succesfully?
if succes, could you please tell how to do?
Now, I integrate meta-updater to my board: NXP iMX6ULL EMMC 1GB
It hard and not simple.
Maybe You could help me.
Best wishes
Kingdekong
Hello @kingdekong. I moved to another company and unfortunately I’m not working on that anymore since more than a year ago.
Hi @kingdekong !
TorizonCore is currently supported on Colibri iMX6ULL 1GB (eMMC). Maybe you want to test it. :slight_smile:
https://www.toradex.com/pt-br/computer-on-modules/colibri-arm-family/nxp-imx6ull
Hello @giobauermeister ,Thank you for your response.
I will do my utmost to do this, although it not easy nor simple.
Thank you!
Hi, @henrique.tx ,Thank you for your response.
I have purchased :Iris Carrier Board V2.0A Colibri and iMX6ULL 1GB IT V1.1A.
But I want to STUDY how to port ostree (meta-updater) to my board: NXP iMX6ULL EMMC 1GB.
Could you give me some help? Such as: web link, document etc. Every resource about porting ostree (meta-updater)
Thank you!
Hi @kingdekong
I see… I don’t think I can help you much…
But, if I was you, I would download TorizonCore layers (you can follow Build Torizon OS from Source With Yocto Project/OpenEmbedded | Toradex Developer Center) and check how it is done there.
Hopefully, it will give you some good pointers.
Hello @kingdekong ,
Do you have any updates on this topic?
Josep
