Meta-toradex-security
im using meta-toradex-security to sign a fit image,why do we only provide the private signing key UBOOT_SIGN_KEYNAME which is responsible for signing the fit image and not provide the public key which is needed to be included inside the DTBO?
(1)
Looking at the FIT image signing configuration in meta-toradex-security, you actually don’t need to manually provide the public key because the build system automatically handles the public key inclusion in the U-Boot device tree. (1)
How the Key Management Works
When you configure FIT image signing with UBOOT_SIGN_KEYNAME, the system uses both the private and public keys: (1)
  • The private key (${UBOOT_SIGN_KEYNAME}.key) is used to sign the FIT image during the build process (1)
  • The public key (${UBOOT_SIGN_KEYNAME}.crt) is automatically embedded into U-Boot’s device tree blob (DTB) for verification (1)
Key Configuration Variables
The relevant variables for FIT image signing include: (1)
Variable Description Default value
UBOOT_SIGN_KEYDIR Location of the RSA key and certificate used for signing ${TOPDIR}/keys/fit
UBOOT_SIGN_KEYNAME The name of the key used for signing configuration nodes dev
FIT_GENERATE_KEYS Generate signing keys 1
Automatic Key Generation and Embedding
When FIT_GENERATE_KEYS = "1" (the default), the build system: (1)
  1. Automatically generates both private key and public certificate files
  2. Uses the private key to sign the FIT image
  3. Embeds the public key into U-Boot’s device tree for runtime verification
The public key embedding happens automatically through the uboot-sign and kernel-fitimage classes from OpenEmbedded Core, which meta-toradex-security leverages. (1)
This design ensures that U-Boot has the necessary public key information built-in to verify the FIT image signatures at boot time, while keeping the private signing key secure in your build environment.
Greetings @anmsn44,
I believe you have a misunderstanding on how these variables work. The AI gave a fairly good response, but just to be clear.
I assume you have FIT_GENERATE_KEYS set in your build or at least you didn’t change it, which means the default is to be enabled. This will cause the build to auto-generate keys for signing the FIT image. Both the private and public key.
The variable you are asking about UBOOT_SIGN_KEYNAME, is simply what filename the keys (both public and private) are. For example if UBOOT_SIGN_KEYNAME = foo then the key filenames are foo.crt and foo.key.
If you have FIT_GENERATE_KEYS disabled, then you must set UBOOT_SIGN_KEYNAME accurately to reflect the filename of the keys that you’re providing yourself.
