For those interested, I’ve submitted a PR on the mender repos. It adds support for Mender on the colibri imx6ull SOM.
I smoke tested it and it works, please feel free to test it and comment, submit changes, etc.
Hello rsanchez,
thank you for sharing!
Matthias
Hello @rsanchez
Thank you for your work!
I also tested it and it works.
My problem is that, after adding other packages and applications needed for my project I only got 6MB left. So I’ll probably have to opt for meta-updater and OSTree.
Hi @giobauermeister
Thank you for testing it.
And yes, unfortunately using mender implies disregarding half of the flash space, so is not suitable for every project. I’m now in a similar situation also, so probably will give it a go to to OSTree as well.
if you want to use OS Tree check out our Torizion OS that is using OSTree.
Matthias Gohlke
For those interested on Mender:
The pull request including the colibri imx6ull integration has been merged into the meta-mender-community repo in “dunfell” branch. So it can now be considered as an official integration.
thanks thats good
