While investigating a memory leak I found an unexpected behavior and I’d like sharing my thoughts.
I have a Colibri VF61 V1.2A with the official Win CE6 1.5 downloaded from Toradex website.
Every time I plug USB cable in X29 connector of Evaluation Board V3.2A, Windows Mobile Center pops up on my Win 7 laptop.
On Colibri module I launched Start >> Control Panel >> System Poperties and I switched to “Memory” tab.
I noticed that every time I plug the USB cable, the Program Memory In Use
In my use case I use the Windows Mobile Device Center to share files between a PC and the device, and so I’m worried about this memory leak.
I understand that other users could have different needs, but a fix would be necessary for me.
Moreover I see that this topic has been closed because I opened a different one here.
This is not true because this memory leak happens with USBOTG driver too (not only UFN). The problem in the other topic is related to UFN only.
Thank you for reporting this isssue. I was able to reproduce it here in our office.
In general a memory leak is an issue for longterm stability. However, the Windows Mobile Device Center (WMDC) connectivity is a feature that our customers use almost only during the development phase. Therefore we treat this particular problem to be uncritical, so we will process it with low priorty only.
Let us know if your use case is different and you need a fix soon.
We found a memory leak in part of active sync service application(rnaapp.exe). It is Microsoft code. Could you please wait for some more days, we need to do little more investigation and let you know the update as soon as we done.
Thank you for your patience. We spent some time to analysis the memory leak issue. We are unable to find the root cause of the memory leak during Active sync connection launch and terminate with all the available tools.
The amount of memory leaking is not that big, it was on CE 7 Vybrid vf 61 arround 12kbyte per loop (when plugged out, the memory increased by 12 kb with each plug in / plug out loop).
There are some process launching during active sync connection establishment and not terminating after disconnecting the cable. There must be something like a message queue or any other shared resource not freeing and which is untraceable through the tools.
Please let us know how much important this issue for your use case.
