Which is the maximum display resolution and frame rate supported by Colibri VF61?
I don’t think so, but is it different between WinCE and Linux?
Hi @vix!
You can check this information on the Colibri VF61 | Toradex Developer Center Datasheet, section 5.5.1:
- The module supports a resolution of 1024x768, 24bpp, with a max pixel clock of 60MHz.
