MAX98357A on imx7s with simple-audio-card
Hello!
I try to get an external codec (MAX98357A) running on the Colibri i.MX7S module, but until now with no success.
The driver, that I added seems to be there and gets loaded
root@b2qt-colibri-imx7:~# lsmod
Module                  Size  Used by
snd_soc_simple_card    16384  0
snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
imx_sdma               28672  4
virt_dma               16384  1 imx_sdma
ili210x                16384  0
snd_soc_max98357a      16384  1
libcomposite           49152  0
configfs               40960  2 libcomposite
When I try to play something using the aplay, the program gets stuck, but listing the devices seems to work
root@b2qt-colibri-imx7:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: max98357a [max98357a], device 0: 308b0000.sai-HiFi HiFi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
root@b2qt-colibri-imx7:~# aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
sysdefault:CARD=max98357a
    max98357a,
    Default Audio Device
In the device tree, I have the following settings to use SAI2 as output
	model = "Toradex Colibri iMX7S on Colibri Evaluation Board V3";
	compatible = "toradex,colibri-imx7s-eval-v3", "toradex,colibri-imx7s",
		     "fsl,imx7s";
	//external Sound chip driver configuration
	codec_ext: max98357a@0 {
		compatible = "maxim,max98357a";
		#sound-dai-cells = <0>;
	sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "max98357a";
		simple-audio-card,format = "i2s";
		simple-audio-card,bitclock-master = <&dailink_master>;
		simple-audio-card,frame-master = <&dailink_master>;
		simple-audio-card,cpu {
			sound-dai = <&sai2>;
		dailink_master: simple-audio-card,codec {
			sound-dai = <&codec_ext>;
			clocks = <&clks IMX7D_AUDIO_MCLK_ROOT_CLK>;
 		cpu_dai: simple-audio-card,cpu {
			sound-dai = <&sai2 0>;
&iomuxc {
pinctrl_sai2: sai2-grp {
		fsl,pins = <
			//Pin31
			MX7D_PAD_SD2_DATA1__SAI2_TX_BCLK 0x1f
			//Pin100
			MX7D_PAD_SD2_DATA2__SAI2_TX_SYNC 0x1f
			//Pin102
			MX7D_PAD_SD2_DATA3__SAI2_TX_DATA0 0x30
//disable the internal i2s
&sai1 {
	status = "disabled";
//enable the external i2s that we want to use
&sai2 {
	fsl,mode = "i2s-master";
	pinctrl-names = "default";
	pinctrl-0 = <&pinctrl_sai2>;
	assigned-clocks = <&clks IMX7D_SAI2_ROOT_SRC>,
		<&clks IMX7D_SAI2_ROOT_CLK>;
	assigned-clock-parents = <&clks IMX7D_PLL_AUDIO_POST_DIV>;
	assigned-clock-rates = <0>, <36864000>;
//Remove all additional port pins from the uart and leave it with only RTS/CTS handshake
//Because we require one of these pins for SAII2
&uart1 {
	pinctrl-0 = <&pinctrl_uart1>;
//Remove pins 100 and 102 from the GPIO list, because we require them for the SAI2
&pinctrl_gpio1 {
	fsl,pins = <
		MX7D_PAD_SAI1_RX_SYNC__GPIO6_IO16	0x14 /* SODIMM 77 */
		MX7D_PAD_EPDC_DATA09__GPIO2_IO9		0x14 /* SODIMM 89 */
		MX7D_PAD_EPDC_DATA08__GPIO2_IO8		0x74 /* SODIMM 91 */
		MX7D_PAD_LCD_RESET__GPIO3_IO4		0x14 /* SODIMM 93 */
		MX7D_PAD_EPDC_DATA13__GPIO2_IO13	0x14 /* SODIMM 95 */
		MX7D_PAD_ENET1_RGMII_TXC__GPIO7_IO11	0x14 /* SODIMM 99 */
		MX7D_PAD_EPDC_DATA10__GPIO2_IO10	0x74 /* SODIMM 105 */
		MX7D_PAD_EPDC_DATA00__GPIO2_IO0		0x14 /* SODIMM 111 */
		MX7D_PAD_EPDC_DATA01__GPIO2_IO1		0x14 /* SODIMM 113 */
		MX7D_PAD_EPDC_DATA02__GPIO2_IO2		0x14 /* SODIMM 115 */
		MX7D_PAD_EPDC_DATA03__GPIO2_IO3		0x14 /* SODIMM 117 */
		MX7D_PAD_EPDC_DATA04__GPIO2_IO4		0x14 /* SODIMM 119 */
		MX7D_PAD_EPDC_DATA05__GPIO2_IO5		0x14 /* SODIMM 121 */
		MX7D_PAD_EPDC_DATA06__GPIO2_IO6		0x14 /* SODIMM 123 */
		MX7D_PAD_EPDC_DATA07__GPIO2_IO7		0x14 /* SODIMM 125 */
		MX7D_PAD_EPDC_SDCE2__GPIO2_IO22		0x14 /* SODIMM 127 */
		MX7D_PAD_UART3_RTS_B__GPIO4_IO6		0x14 /* SODIMM 131 */
		MX7D_PAD_EPDC_GDRL__GPIO2_IO26		0x14 /* SODIMM 133 */
		MX7D_PAD_SAI1_RX_DATA__GPIO6_IO12	0x14 /* SODIMM 169 */
		MX7D_PAD_SAI1_RX_BCLK__GPIO6_IO17	0x14 /* SODIMM 24 */
		MX7D_PAD_EPDC_GDSP__GPIO2_IO27		0x14 /* SODIMM 104 */
		MX7D_PAD_EPDC_BDR1__GPIO2_IO29		0x14 /* SODIMM 110 */
		MX7D_PAD_EPDC_PWR_COM__GPIO2_IO30	0x14 /* SODIMM 112 */
		MX7D_PAD_EPDC_SDCLK__GPIO2_IO16		0x14 /* SODIMM 114 */
		MX7D_PAD_EPDC_SDLE__GPIO2_IO17		0x14 /* SODIMM 116 */
		MX7D_PAD_EPDC_SDOE__GPIO2_IO18		0x14 /* SODIMM 118 */
		MX7D_PAD_EPDC_SDSHR__GPIO2_IO19		0x14 /* SODIMM 120 */
		MX7D_PAD_EPDC_SDCE0__GPIO2_IO20		0x14 /* SODIMM 122 */
		MX7D_PAD_EPDC_SDCE1__GPIO2_IO21		0x14 /* SODIMM 124 */
		MX7D_PAD_EPDC_DATA14__GPIO2_IO14	0x14 /* SODIMM 126 */
		MX7D_PAD_EPDC_PWR_STAT__GPIO2_IO31	0x14 /* SODIMM 128 */
		MX7D_PAD_EPDC_SDCE3__GPIO2_IO23		0x14 /* SODIMM 130 */
		MX7D_PAD_EPDC_GDCLK__GPIO2_IO24		0x14 /* SODIMM 132 */
		MX7D_PAD_EPDC_GDOE__GPIO2_IO25		0x14 /* SODIMM 134 */
		MX7D_PAD_EPDC_DATA12__GPIO2_IO12	0x14 /* SODIMM 150 */
		MX7D_PAD_EPDC_DATA11__GPIO2_IO11	0x14 /* SODIMM 152 */
		MX7D_PAD_SD2_CLK__GPIO5_IO12		0x14 /* SODIMM 184 */
		MX7D_PAD_SD2_CMD__GPIO5_IO13		0x14 /* SODIMM 186 */
I grabbed the signals on an Iris Board and forwarded them to an ‘Adafruit MAX98357 I2S Class-D Mono Amp’ Board where I made the follwing connections
SAI2_TX_BCLK (Pin31) -> BCLK
SAI2_TX_SYNC (Pin100) -> LRC
SAI2_TX_DATA0 (Pin102) -> DIN
What I can see, when analysing the signals with an oscilloscope is that BCLK and SYNC constantly stay on GND level, whether DATA0 is first on 3V3, but during boot jumps to 5V0 and constantly stays there.
I think something is wrong with my device tree setting, may someone help me to correct the settings?
HI @alins
Could you share the dmesg.log in a text file?
Did you check if the sai clock is enabled : cat /sys/kernel/debug/clk/clk_summary | grep sai2?
Thanks and best regards,
Hi jaski.tx!
In the meantime I modified the setup a bit. Because I am not sure, if the codec is configured properly, I just routed the original sgtl5000 driver to SAI2 to see at least some kind of port flickering. I also changed the DATA line to pin 31, because pin 102 is used to enable/disable the UART1 transceiver on the Iris board, which I am using as terminal port. The modified dts now has the following contents:
		     "fsl,imx7s";
	sound {
		simple-audio-card,name = "imx7-sgtl5000";
			sound-dai = <&codec>;
			clocks = <&clks 330>;
&iomuxc {
		fsl,pins = <
			//Pin31
			//Pin100
			//Pin102
			//MX7D_PAD_SD2_DATA3__SAI2_TX_DATA0 0x30
			//Pin31
			MX7D_PAD_SAI2_TX_DATA__SAI2_TX_DATA0 0x30
&sai2 {
&uart1 {
//Remove pins 100 and 102 from the GPIO list, because we require it for the SAI2
&pinctrl_gpio1 {
	fsl,pins = <
		MX7D_PAD_SD2_DATA3__GPIO5_IO17		0x14 /* SODIMM 102 */
//Disable UART 2 to use its port pins for SAI2
&uart2 {
Unfortunately the port pins still do not do anything.
Here is the requested data:
root@b2qt-colibri-imx7:~# cat /sys/kernel/debug/clk/clk_summary | grep sai
    sai3_src                              0            0    24000000          0 0
       sai3_cg                            0            0    24000000          0 0
          sai3_pre_div                    0            0    24000000          0 0
             sai3_post_div                0            0    24000000          0 0
                sai3_root_clk             0            0    24000000          0 0
    sai2_src                              0            0    24000000          0 0
       sai2_cg                            0            0    24000000          0 0
          sai2_pre_div                    0            0    24000000          0 0
             sai2_post_div                0            0    24000000          0 0
                sai2_root_clk             0            0    24000000          0 0
    sai1_src                              0            0    24000000          0 0
       sai1_cg                            0            0    24000000          0 0
          sai1_pre_div                    0            0    24000000          0 0
             sai1_post_div                0            0    24000000          0 0
                sai1_root_clk             0            0    24000000          0 0
                               sai3_ipg_clk           0            0    67500000          0 0
                               sai2_ipg_clk           0            1    67500000          0 0
                               sai1_ipg_clk           0            1    67500000          0 0
dmesg.txt
Thanks for the clk_summary and the dmesg.log.
What is the output of aplay -L?
Usually these clock are only enabled when you try to play something on the sound device.
Hi
Note that in I2S depending on the used system configuration either the codec or the cpu provides the bit and frame clocks.
The MAX98357 seems to only be able to receive those clocks. So the following is wrong as it would require the codec to generate those clocks:
I would replace the label ‘cpu_dai’ with ‘dailink_master’. and don’t give the simple-audio-card,codec node a label at all.
    dailink_master: simple-audio-card,cpu {
Max
@max.tx
Thank you for your reply!
I changed my dts file to the following:
	sound {
		simple-audio-card,bitclock-master = <&dailink_master_cpu>;
		simple-audio-card,frame-master = <&dailink_master_cpu>;
		dailink_master_cpu: simple-audio-card,cpu {
(I could not reuse ‘dailink_master’ as label, because it seems to be defined somewhere else in the included dtsi files so that the dtc complains about this reuse)
If I now try to play some audio, I get the following error:
null
    max98357a,
root@b2qt-colibri-imx7:~# aplay sounds/error.wav
[  389.041220] fsl-sai 308b0000.sai: failed to derive required Tx rate: 1536000
[  389.048327] fsl-sai 308b0000.sai: ASoC: can't set 308b0000.sai hw params: -22
ALSA lib ../../../alsa-lib-1.1.8/src/pcm/pcm_direct.c:1271:(snd1_pcm_direct_initialize_slave) unable to install hw params
ALSA lib ../../../alsa-lib-1.1.8/src/pcm/pcm_dmix.c:1120:(snd_pcm_dmix_open) unable to initialize slave
aplay: main:828: audio open error: Invalid argument
I already changed the sai2 configuration to
&sai2 {
	assigned-clock-rates = <0>, <1536000>;
(set “assigned-clock-rates = <0>, <1536000>;”)
But this does not solve the problem. I assume the SAI2 is not properly configured to drive the clock for the codec
@jaski.tx
In the meantime I implemented the changes suggested by max.tx and switched back to the max98357a driver. With the following configuration,
&sai2 {
I got the following output:
null
    max98357a,
                               sai1_ipg_clk           0            0    67500000          0 0
Have you tried something like in this patch?
@max.tx
Thank you, this was the solution. With the following dts file, the codec is now working as expected
/dts-v1/;
#include "imx7s-colibri.dtsi"
#include "imx7-colibri-eval-v3.dtsi"
		     "fsl,imx7s";
	sound {
&iomuxc {
	pinctrl-0 = <&pinctrl_gpio1 &pinctrl_gpio2 &pinctrl_gpio4
		     &pinctrl_gpio5 &pinctrl_gpio6 &pinctrl_gpio7>;
		fsl,pins = <
			//Pin31
			//Pin100
			//Pin32
 	pinctrl_uart1_ctrl1: uart1-ctrl1-grp {
 		fsl,pins = <
 			MX7D_PAD_SD2_DATA0__GPIO5_IO14		0x14 /* DTR */
&sai1 {
&sai2 {
	assigned-clocks = <&clks IMX7D_SAI2_ROOT_SRC>, <&clks IMX7D_SAI2_ROOT_CLK>, <&clks IMX7D_PLL_AUDIO_POST_DIV>;
	assigned-clock-rates = <0>, <36864000>, <589824000>;
&uart1 {
&pinctrl_gpio1 {
	fsl,pins = <
&uart2 {
Perfect that it works.
Thanks for the feedback.
