5.4.161-39955-g585dc27c53b6-dirty
Verdin IMX8MP Q
I am trying to get some audio out on I2S2 or sai3 on SODIMM 42,44,46,48
I added the MAX98357 to my Kernel config and tried to add this device to my device tree:
// SPDX-License-Identifier: GPL-2.0+ OR MIT
* Copyright 2020 Toradex
/dts-v1/;
#include "imx8mp-verdin.dtsi"
#include "imx8mp-verdin-wifi.dtsi"
#include "imx8mp-verdin-dahlia.dtsi"
model = "Toradex Verdin iMX8M Plus WB on Dahlia Board";
compatible = "toradex,verdin-imx8mp-wifi-dahlia",
"toradex,verdin-imx8mp-wifi",
"toradex,verdin-imx8mp",
"fsl,imx8mp";
codec_ext: max98357a@0 {
compatible = "maxim,max98357a";
#sound-dai-cells = <0>;
sound_ext {
compatible = "simple-audio-card";
simple-audio-card,name = "max98357a";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&dailink_master1>;
simple-audio-card,frame-master = <&dailink_master1>;
dailink_master1: simple-audio-card,cpu {
sound-dai = <&sai3>;
simple-audio-card,codec {
sound-dai = <&codec_ext>;
clocks = <&audiomix_clk IMX8MP_CLK_AUDIOMIX_SAI3_MCLK1>;
&fec {
status = "disabled";
&flexspi {
&iomuxc {
pinctrl_sai3: sai3grp {
fsl,pins = <
MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0x1d6 /* SODIMM 44 */
MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0x1d6 /* SODIMM 42 */
MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0x96 /* SODIMM 46 */
pinctrl_uart1: uart1grp {
fsl,pins = <
MX8MP_IOMUXC_UART1_RXD__UART1_DCE_RX 0x1c4 /* SODIMM 129 */
MX8MP_IOMUXC_UART1_TXD__UART1_DCE_TX 0x1c4 /* SODIMM 131 */
pinctrl_uart2: uart2grp {
fsl,pins = <
MX8MP_IOMUXC_UART2_RXD__UART2_DCE_RX 0x1c4 /* SODIMM 137 */
MX8MP_IOMUXC_UART2_TXD__UART2_DCE_TX 0x1c4 /* SODIMM 139 */
/* VERDIN I2S_2 */
&sai3 {
status= "okay";
/* Verdin UART_1 */
&uart1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart1>;
/* Verdin UART_2 */
&uart2 {
pinctrl-0 = <&pinctrl_uart2>;
/* Verdin UART_3, used as the Linux Console */
&uart3 {
pinctrl-0 = <&pinctrl_uart3>;
/* Verdin I2C_4_CSI */
&i2c3 {
status= "okay";
clock-frequency = <400000>;
pinctrl-names = "default", "gpio";
pinctrl-0 = <&pinctrl_i2c3>;
pinctrl-1 = <&pinctrl_i2c3_gpio>;
scl-gpios = <&gpio5 18 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
sda-gpios = <&gpio5 19 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>;
ili251x@41 {
compatible = "ili251x";
reg = <0x41>;
interrupt-parent = <&gpio1>;
interrupts = <1 IRQ_TYPE_EDGE_RISING>;
reset-gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>;
max-fingers = <6>;
wakeup-source;
The system seems to have some success in detecting the driver etc:
[ 2.522774] debugfs: Directory ‘30c30000.sai’ with parent ‘max98357a’ already present!
[ 2.530794] asoc-simple-card sound_ext: HiFi ↔ 30c30000.sai mapping ok
[ 3.106274] ALSA device list:
[ 3.109271] #0: max98357a
Trying to play some music then gives me this error:
root@verdin-imx8mp-07129898:~# aplay PinkPanther60.wav
[ 45.214270] fsl-sai 30c30000.sai: failed to derive required Tx rate: 1411200
[ 45.221378] fsl-sai 30c30000.sai: ASoC: can’t set 30c30000.sai hw params: -22
ALSA lib ../../../alsa-lib-1.2.1.2/src/pcm/pcm_direct.c:1271:(snd1_pcm_direct_initialize_slave) unable to install hw params
ALSA lib ../../../alsa-lib-1.2.1.2/src/pcm/pcm_dmix.c:1101:(snd_pcm_dmix_open) unable to initialize slave
aplay: main:828: audio open error: Invalid argument
Any ideas what is going wrong?
