Hi, I should read CAN1_MCR register of Vybrid VF61. Address is 0x400D4000 according VF61 reference manual. This code doesn’t work and exception is thrown:
void MemTest()
	volatile DWORD *pMem;
	HANDLE mapMem;
	DWORD regValue;
	mapMem = Map_Init();
	pMem = (DWORD*)Map_MapMemory(0x400D4000,4);
	regValue = *pMem;
	Map_UnMapMemory((LPVOID)pMem);
	Map_Deinit(mapMem);
The exception is thrown when doing regValue = *pMem.
I tried the same code with another address (IO ports) and works, is this related to the supervisor access type? In that case how can I switch the access type to Unrestricted?
Thanks!
