Mallow V1.1 - Dimensioned drawing
Is there a dimensioned drawing of the Mallow board available?
I need to position connectors and mounting points on our base board.
Thanks,
Dean
Hello @dean,
We have an assembly drawing at 5:2 scale and some mechanical models. All of them listed here
Would that work for you?
Josep
I was hoping to find a drawing with dimensions written on, from mounting point to connector origins?
This would allow the most precise positioning for me.
Is this something you are able to produce?
Hello @Dean ,
I have asked internally to produce them. I will update this thread when I have new information on this topic.
Josep
Hello @Dean ,
I have been informed that the dimensioned drawing for the Mallow should be published at the end of next week.
Josep
You can download the STEP model of the Mallow board and use a measuring tool in the eDrawings model viewer to obtain coordinates for any mounting points or other components.
Hello @Dean ,
The dimensioned drawings have bee added in the data sheet Rev. 1.2 ( section 4, mechanical data)
Josep
Thank you very much.
Dean
