The new mallow carrier board includes a PCIe M.2 (key B) interface. I understand that this connector type will support a SATA SSD with key B+M, but I am confused about the PCIe lanes and what this particular board will support.
My question is, will this interface on the Mallow board support an SATA SSD with either a (key B) or (key B+M) interface? Is there an example SSD product that has been tested with this board? I am using the Verdin iMX8M Plus module.
@marcel.tx, thank you for the quick response and the clarity. I had assumed that the NVMe protocol was yet another specification that was not supported on this interface. This is great news. Also, thank you for the example products.. this was exactly what I needed.
Hi @marcel.tx, I have a somewhat related question… regarding the Dahlia board. The Mallow are in short supply right now… so I am going to switch my product MVP to use the Dahlia. This board also has a mini-PCIe interface…
Do you know if the above drives (i.e. Western Digital CL SN520 NVMe SSD) will work with that interface as well? The docs do not mention the Key for this interface.
The Dahlia board feature an mini PCIe slot while NVMe SSD use M2 slot.
Most likely that this adapter (Amazon.com: M.2 (NGFF) NVME SSD to Mini PCIe Adapter : Electronics) will be compatible with the Dahlia or Verdin development board. However, without access to the schematic of the adapter, I cannot guarantee its functionality.
Please also note that the Verdin module includes a single-lane PCIe interface, so 2x or 4x NVMe drives should work, but the data throughput will be limited due to the single-lane configuration.
Hi All,
has anyone successfully used the M.2 B slot to connect NIC peripheral, specifically Intel i210 comm?
Is the Intel i210 controller supported out of the box in the Torizon OS kernel, or does it require a custom device tree overlay?
