I am trying to improve my makefile and development environment. Currently I have the below structure
rifo@rifo:~/projects/agi/toradex/$ tree
├── hello3
├── inc
│ ├── json.h
│ └── post.h
├── makefile
└── src
├── json.c
├── main.c
└── post.c
For the above structure, I use the below makefile and everything turns out fine. (Note that I use #include “../inc/post.h” “../inc/json.h” in my source files)
SYSROOTS ?= /usr/local/oecore-x86_64/sysroots
CC = ${SYSROOTS}/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc
INCLUDES = -I${SYSROOTS}/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include
LIB_PATH = -L${SYSROOTS}/armv7at2hf-neon-angstrom-linux-gnueabi/lib
LIBS = -lpthread -lcurl -ljansson
CFLAGS = -O0 -g -Wall -std=gnu99 -mfloat-abi=hard --sysroot=${SYSROOTS}/armv7at2hf-neon-angstrom-linux-gnueabi
all: $(TARGET)
${CC} ${CFLAGS} ${INCLUDES} ${LIB_PATH} ${LIBS} src/json.c src/post.c src/main.c -o hello3
clean:
rm -rf hello3
Now I want to have an extra folder called “obj” where I can place the object files. In my makefile, I want to first compile every source file and then link it at the end.
├── hello3
├── inc
│ ├── json.h
│ └── post.h
├── makefile
├── obj
│ ├── json.o
│ ├── main.o
│ └── post.o
└── src
├── json.c
├── main.c
└── post.c
For this structure, I tried the below makefile but can’t get it working. Can you please guide me for solving this problem?
INCLUDES = -I${SYSROOTS}/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include -I./inc
CPP_FILES = $(wildcard src/*.c)
OBJ_FILES = $(addprefix obj/, $(notdir $(CPP_FILES:.c=.o)))
TARGET = json_post
all: $(TARGET)
$(TARGET): $(OBJ_FILES)
$(CC) -o $(TARGET) ${LIB_PATH} $(LIBS) $^
obj/%.o: src/%.c $(DEPS)
$(CC) $(CFLAGS) $(INCLUDES) -c -o $@ $<
clean:
rm ./${TARGET} obj/*.o
I have used a very similar make file for compiling the same project on Beaglebone Black (no cross compiling) so in theory I expected this to work however I got the below errors
rifo@rifo:~/projects/agi/toradex/$ make
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc -O0 -g -Wall -std=gnu99 -mfloat-abi=hard --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include -I./inc -c -o obj/post.o src/post.c
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc -O0 -g -Wall -std=gnu99 -mfloat-abi=hard --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include -I./inc -c -o obj/main.o src/main.c
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc -O0 -g -Wall -std=gnu99 -mfloat-abi=hard --sysroot=/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi -I/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include -I./inc -c -o obj/json.o src/json.c
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/arm-angstrom-linux-gnueabi-gcc -o json_post -L/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/lib -lpthread -lcurl -ljansson obj/post.o obj/main.o obj/json.o
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot open crt1.o: No such file or directory
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot open crti.o: No such file or directory
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot open crtbegin.o: No such file or directory
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot open crtend.o: No such file or directory
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot open crtn.o: No such file or directory
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot find -lpthread
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot find -lcurl
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot find -ljansson
/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/arm-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/5.2.1/real-ld: error: cannot find -lgcc
src/post.c:30: error: undefined reference to 'curl_slist_append'
src/post.c:31: error: undefined reference to 'curl_slist_append'
src/post.c:33: error: undefined reference to 'curl_easy_init'
src/post.c:41: error: undefined reference to 'curl_easy_setopt'
src/post.c:42: error: undefined reference to 'curl_easy_setopt'
src/post.c:43: error: undefined reference to 'curl_easy_setopt'
src/post.c:46: error: undefined reference to 'curl_easy_setopt'
src/post.c:51: error: undefined reference to 'strlen'
src/post.c:54: error: undefined reference to 'curl_easy_perform'
src/post.c:58: error: undefined reference to 'stderr'
src/post.c:58: error: undefined reference to 'curl_easy_strerror'
src/post.c:58: error: undefined reference to 'fprintf'
src/post.c:65: error: undefined reference to 'curl_easy_cleanup'
src/post.c:69: error: undefined reference to 'puts'
src/post.c:79: error: undefined reference to 'curl_global_cleanup'
/usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/include/jansson.h:112: error: undefined reference to 'json_delete'
src/main.c:37: error: undefined reference to 'puts'
src/main.c:39: error: undefined reference to 'json_dumps'
src/main.c:40: error: undefined reference to 'puts'
src/main.c:43: error: undefined reference to 'free'
src/main.c:44: error: undefined reference to 'sleep'
src/main.c:62: error: undefined reference to 'curl_global_init'
src/main.c:64: error: undefined reference to 'pthread_create'
src/main.c:66: error: undefined reference to 'pthread_join'
src/json.c:19: error: undefined reference to 'json_pack'
collect2: error: ld returned 1 exit status
makefile:14: recipe for target 'json_post' failed
make: *** [json_post] Error 1
thanks a lot for your help
rifo
