Makefile or build system is incorrectly configured
Hello, i’m trying to makefile a project for drivers, using Buildroot, but once i do “make” it appears these errors:
aarch64-buildroot-linux-gnu-gcc.br_real: erro: unrecognized argument in option ‘-mabi=apcs-gnu’
aarch64-buildroot-linux-gnu-gcc.br_real: nota: valid arguments to ‘-mabi=’ are: ilp32 lp64
aarch64-buildroot-linux-gnu-gcc.br_real: erro: unrecognized command-line option ‘-mapcs’
aarch64-buildroot-linux-gnu-gcc.br_real: erro: unrecognized command-line option ‘-mno-sched-prolog’
aarch64-buildroot-linux-gnu-gcc.br_real: erro: unrecognized command-line option ‘-msoft-float’
I have this in my makefile:
obj-m := led.o
led-objs:=ledmodule.o utils.o
KDIR := /home/$USER/buildroot/buildroot-2024.08/output/build/linux-custom/
ARCH ?= arm
CROSS_COMPILE ?= /home/$USER/buildroot/buildroot-2024.08/output/host/bin/aarch64-buildroot-linux-gnu-
export ARCH CROSS_COMPILE
KBUILD_TARGETS := clean help modules modules_install
.PHONY: all $(KBUILD_TARGETS)
all: modules
$(KBUILD_TARGETS):
#$(MAKE) -C $(KDIR) M=$(shell pwd) $@ EXTRA_CFLAGS=“$(MY_CFLAGS)”
Do you know what do i have to do?
The errors you’re encountering suggest that the compiler is being given options that are not valid for the architecture you’re targeting. Specifically, the options -mabi=apcs-gnu, -mapcs, -mno-sched-prolog, and -msoft-float are not recognized by the aarch64-buildroot-linux-gnu-gcc compiler, which is meant for the AArch64 architecture (64-bit ARM).
Here are a few steps you can take to resolve these issues:
  1. Check Compiler Flags: Ensure that your Makefile or any included files are not setting these invalid flags. These flags seem to be intended for older ARM architectures (like ARMv4 or ARMv5), not AArch64.
  2. Correct Architecture: Make sure that the ARCH variable is set correctly. Since you’re using an AArch64 toolchain, ARCH should be set to arm64 instead of arm.
  3. Toolchain Compatibility: Verify that the toolchain you are using is compatible with the target architecture. The aarch64-buildroot-linux-gnu-gcc toolchain is for 64-bit ARM, so ensure your project is intended for this architecture.
  4. Review Makefile: Double-check your Makefile and any included files for any hardcoded or default flags that might be causing these issues. Remove or replace them with appropriate flags for AArch64.
  5. Buildroot Configuration: If you are using Buildroot, ensure that the configuration is set up correctly for your target architecture. You might need to reconfigure Buildroot to ensure it generates the correct toolchain and settings for your target.
By addressing these points, you should be able to resolve the errors and successfully compile your project.
https://community.nxp.com/t5/i-MX-Processors/Cross-compilation-issue-with-QT5-6-and-imx6/td-p/499623/?profile.language=en.
Hi @luis_batista !
We currently support and recommend using Yocto Project instead of Buildroot to build your image.
Could you check the article about how to Build a Reference Image with Yocto Project/OpenEmbedded and see if you can achieve what you are expecting, please?
Best regards.
Lucas Azeituno.
