I am using the angstrom-lxde image on Colibri T30.
We configured our DHCP server to set a static lease based on the MAC address. However, this address is changed on reboot.
00:0e:c6:8f:XX:XX
These parts change on reboot.
How can I disable this anti-feature?
Please have a look at the following article on our developer website.
Thank you, I could “Permanently Manually Force a Custom MAC Address”.
But I do not understand why the MAC changed in the first place if “last 3 bytes represent the serial number found on the label (in hexadecimal)”?
Most probably you corrupted the Toradex factory configuration block and using U-Boot’s cfgblock create command allows to restore it again.
