PG03
October 20, 2020, 1:46pm
1
I want to use Qt to create a UI, therefore I need to configure the toolchain for cross compiling.
I followed your tutorials for OpenEmbedded and Qt Creator to cross compile and all worked fine.
But now I get this message:
ERROR: Task (/media/phillip/Ext_Linux/oe-core/build/../layers/openembedded-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_compile) failed with exit code ‘1’
How can I solve this?
Hi @PG03 ,
Please provide more information about:
Which BSP are you planning to use?
Which version of Qt are you planning to use?
You mentioned a “Colibri V1.1A”, is it the carrier board? If so, which model?
The compilation message error also provides a more detailed output, could you provide that? Please feel free to upload a text file with the logs.
André Curvello
PG03
October 23, 2020, 9:51am
3
I want to use Linux BSP 2.8.7
Qt 5 (but I can switch to an older version if necessary)
I use the Colibri Evaluation Board V3.2B
This is the whole output:
phillip@pop-os:/media/phillip/Ext_Linux/oe-core$ bitbake -k angstrom-qt5-x11-image
WARNING: /media/phillip/Ext_Linux/oe-core/build/../layers/openembedded-core/meta/lib/oe/maketype.py:99: DeprecationWarning: Using or importing the ABCs from 'collections' instead of from 'collections.abc' is deprecated since Python 3.3, and in 3.9 it will stop working
if not isinstance(obj, collections.Callable):
Loading cache: 100% |############################################| Time: 0:00:01
Loaded 3900 entries from dependency cache.
WARNING: No recipes available for:
/media/phillip/Ext_Linux/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium-wayland_48.0.2548.0.bbappend
/media/phillip/Ext_Linux/oe-core/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium_52.0.2743.76.bbappend
/media/phillip/Ext_Linux/oe-core/build/../layers/meta-toradex-tegra/recipes-graphics/wayland/weston_1.%.bbappend
/media/phillip/Ext_Linux/oe-core/build/../layers/meta-toradex-tegra/jetson-tk1/recipes-graphics/xorg-xserver/xserver-xorg_1.17.2.bbappend
Build Configuration:
BB_VERSION = "1.36.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "pop-20.04"
TARGET_SYS = "arm-angstrom-linux-gnueabi"
MACHINE = "colibri-imx7-emmc"
DISTRO = "angstrom"
DISTRO_VERSION = "v2017.12"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-angstrom = "HEAD:4318892e08ea9102d29bdd92af83539bea985e4b"
meta-toradex-nxp = "HEAD:dcb75200b15086bcd69f7ff396da7caf413ffb93"
meta-freescale = "HEAD:1d40ea34fc2c06af79fc59f6ea54f2e9335d61d6"
meta-freescale-3rdparty = "HEAD:9056f60d81abacc2d8ee0f83ef0f70dfeedc76c7"
meta-toradex-tegra = "HEAD:16b6bd18785a7cc8d9024a071d3fbc968ff63e83"
meta-jetson-tk1 = "HEAD:b430756e711b6b29381c8467185f475f5a505f96"
meta-toradex-bsp-common = "HEAD:362865913ed40f6cadeaf9111cf83269dc111248"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:eae996301d9c097bcbeb8046f08041dc82bb62f8"
meta-lxde = "HEAD:f436137fcc4ac700dc5c1b5e31e5b3c27568fc3e"
meta-browser = "HEAD:75640e14e325479c076b6272b646be7a239c18aa"
meta-qt4 = "HEAD:e290738759ef3f39c9e079eaa9b606a62107e5ba"
meta-qt5 = "HEAD:180edd66444db330301f22266cac7d588fd48c6a"
meta-qt5-extra = "HEAD:c16ba209a93c3e55f5aef07fbb1d584e228765b3"
meta-freescale-distro = "HEAD:51756d1c2058139c8a21f89b86cfd8007b71b7f0"
meta-toradex-demos = "HEAD:c73893a3377ebb557b0fb41f75b26dff40da4442"
meta = "HEAD:3638cb32ba9ba32b4d498fc31ab7fdf82f0d2495"
Initialising tasks: 100% |#######################################| Time: 0:00:25
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: m4-native-1.4.18-r0 do_compile: oe_runmake failed
ERROR: m4-native-1.4.18-r0 do_compile: Function failed: do_compile (log file is located at /media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/temp/log.do_compile.4083)
ERROR: Logfile of failure stored in: /media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/temp/log.do_compile.4083
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 infodir=/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/share/info
| make all-recursive
| make[1]: Entering directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| Making all in .
| make[2]: Entering directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| make[2]: Nothing to be done for 'all-am'.
| make[2]: Leaving directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| Making all in examples
| make[2]: Entering directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/examples'
| make[2]: Nothing to be done for 'all'.
| make[2]: Leaving directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/examples'
| Making all in lib
| make[2]: Entering directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| make all-am
| make[3]: Entering directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| gcc -I. -I../../m4-1.4.18/lib -isystem/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -isystem/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o freadahead.o ../../m4-1.4.18/lib/freadahead.c
| gcc -I. -I../../m4-1.4.18/lib -isystem/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -isystem/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/recipe-sysroot-native/usr/include -O2 -pipe -c -o fseeko.o ../../m4-1.4.18/lib/fseeko.c
| ../../m4-1.4.18/lib/freadahead.c: In function ‘freadahead’:
| ../../m4-1.4.18/lib/freadahead.c:92:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."
| 92 | #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."
| make[3]: *** [Makefile:1915: freadahead.o] Error 1
| make[3]: *** Waiting for unfinished jobs....
| ../../m4-1.4.18/lib/fseeko.c: In function ‘rpl_fseeko’:
| ../../m4-1.4.18/lib/fseeko.c:110:4: error: #error "Please port gnulib fseeko.c to your platform! Look at the code in fseeko.c, then report this to bug-gnulib."
| 110 | #error "Please port gnulib fseeko.c to your platform! Look at the code in fseeko.c, then report this to bug-gnulib."
| make[3]: *** [Makefile:1915: fseeko.o] Error 1
| make[3]: Leaving directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| make[2]: *** [Makefile:1674: all] Error 2
| make[2]: Leaving directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build/lib'
| make[1]: *** [Makefile:1572: all-recursive] Error 1
| make[1]: Leaving directory '/media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/build'
| make: *** [Makefile:1528: all] Error 2
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /media/phillip/Ext_Linux/oe-core/build/tmp-glibc/work/x86_64-linux/m4-native/1.4.18-r0/temp/log.do_compile.4083)
ERROR: Task (/media/phillip/Ext_Linux/oe-core/build/../layers/openembedded-core/meta/recipes-devtools/m4/m4-native_1.4.18.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2419 tasks of which 2418 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
Thank you for the answer.
Hi @PG03 ,
I haven’t asked, but which operating system are you using for your Yocto Build?
We had a similar issue reported here Ubuntu 18.10/glibc 2.28: Image build fails , and the issue, in the end, was that the user was using an unsupported O.S. (Ubuntu 18.10) for the build.
Please have a look at the Yocto supported distributions .
We still provide support for the BSP 2.8b7, but we strongly advise you to use the BSP 3.0.4 (or 3.0b4), which is our latest LTS BSP, and a supported Linux Distribution for the Yocto Build.
André Curvello
applying the following patch can solve the issue:
committed 04:57PM - 17 Aug 18 UTC
glibc-2.28 did quite some lifting in their headers, which breaks the
way some pa… ckages were detecting glibc, like gnulib.
However, packages do bundle gnulib (it was meant to be bundled),
and so does m4.
Since m4 hasn't seen the slightest commit since 2017-01-09, it is
bundling an old gnulib version, that predates glibc-2.28, and thus
breaks. It also means that upstream hasn't already fixed the issue.
Furthermore, as upstream is using a git submodule for gnulib, and
that the paths are not the same in the release tarball (in lib/)
and in the git tree (in gnulib/), we can't do a plain backport.
So, we selectively backport the two patches from gnulib upstream,
restricted to only the files that happen to be used in m4.
Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr>
Reported-by: c32 on IRC
Signed-off-by: Peter Korsgaard <peter@korsgaard.com>
cheers,
Andre
Thanks for the support, @andreluizeng .
Can you try this, @PG03 ?
André Curvello
