I’m in the process of moving our project from BSP 2.8 to BSP 5.0 and I’m having some difficulties getting the M4 firmware to run.
I’ve compiled a simple freeRTOS project for the M4 for testing, as I can use the standard Colibri Evaluation board and reference images for testing. It sends a “hello world” out the debug UART. The code runs fine on the 2.8 and 3.0 reference image, but on 5.0 I get the following crash:
U-Boot 2020.07-5.0.0+git.3f1b0662d1a7 (Sep 30 2020 - 14:23:37 +0000)
CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 36C
Reset cause: POR
DRAM: 1 GiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
MMC: FSL_SDHC: 1, FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 1GB (eMMC) V1.1A, Serial# 06596547
SEC0: RNG instantiated
Net: eth0: ethernet@30be0000
Hit any key to stop autoboot: 1 0
Colibri iMX7 # <INTERRUPT>
Colibri iMX7 # setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt rm /soc/aips-bus@
30800000/spba-bus@30800000/serial@30890000'
Colibri iMX7 #
Colibri iMX7 # setenv m4boot 'fatload mmc 0:1 ${loadaddr} m4_basic.elf && bootau
x ${loadaddr}'
Colibri iMX7 #
Colibri iMX7 # saveenv
Saving Environment to MMC... Writing to MMC(0)... OK
Colibri iMX7 #
Colibri iMX7 # boot
MMC: no card present
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
3653 bytes read in 19 ms (187.5 KiB/s)
## Executing script at 87000000
2680200 bytes read in 102 ms (25.1 MiB/s)
data abort
pc : [<bff731a0>] lr : [<1fffaa78>]
reloc pc : [<878001a0>] lr : [<e7887a78>]
sp : bdf67fa4 ip : 2000006c fp : 00000002
r10: bdf9e7e0 r9 : bdf70eb0 r8 : 00000000
r7 : bd088000 r6 : f3af4803 r5 : 4903b11b r4 : 4b03b508
r3 : 1fffaa78 r2 : 000029e0 r1 : 80818040 r0 : 1fff8040
Flags: nzcv IRQs on FIQs on Mode SVC_32
Code: e3a0d013 e169f00d e1a0e00f e1b0f00e (e24dd048)
Resetting CPU ...
Any insight as to what is causing this would be very helpful.
Cheers,
Mark
