If it may be useful, here is the boot log:
U-Boot 2019.07-3.0.4+g26d926eda0 (Apr 17 2020 - 21:32:25 +0000)
CPU: Freescale i.MX7D rev1.3 1000 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 41C
Reset cause: POR
DRAM: 512 MiB
PMIC: RN5T567 LSIVER=0x01 OTPVER=0x0d
NAND: 512 MiB
MMC: FSL_SDHC: 0
Loading Environment from NAND... OK
In: serial
Out: serial
Err: serial
Model: Toradex Colibri iMX7 Dual 512MB V1.1D, Serial# 06413914
Net: FEC0
Colibri iMX7 # fatload mmc 0:1 ${loadaddr} demo_m4.elf
275220 bytes read in 35 ms (7.5 MiB/s)
Colibri iMX7 # bootaux ${loadaddr}
## Starting auxiliary core stack = 0x00000000, pc = 0x1FFF80BD...
Colibri iMX7 # run ubiboot
Booting from NAND...
ubi0: default fastmap pool size: 200
ubi0: default fastmap WL pool size: 100
ubi0: attaching mtd5
ubi0: attached by fastmap
ubi0: fastmap pool size: 200
ubi0: fastmap WL pool size: 100
ubi0: attached mtd5 (name "ubi", size 508 MiB)
ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
ubi0: good PEBs: 4052, bad PEBs: 12, corrupted PEBs: 0
ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 97/38, WL threshold: 4096, image sequence number: 1382589019
ubi0: available PEBs: 0, total reserved PEBs: 4052, PEBs reserved for bad PEB handling: 68
No size specified -> Using max size (5937640)
Read 5937640 bytes from volume kernel to 81000000
No size specified -> Using max size (48158)
Read 48158 bytes from volume dtb to 82000000
Kernel image @ 0x81000000 [ 0x000000 - 0x5a99e8 ]
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 8200ec1d
Updating MTD partitions...
Starting kernel ...
[ 0.000000] Linux version 4.14.170-3.0.4+gbaa6c24240a4 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Tue Apr 21 05:00:10 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Toradex Colibri iMX7D on Colibri Custom Board V3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma'
[ 0.000000] cma: Reserved 256 MiB at 0x90000000
[ 0.000000] percpu: Embedded 15 pages/cpu s30924 r8192 d22324 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 242740K/523264K available (8192K kernel code, 353K rwdata, 2432K rodata, 1024K init, 393K bss, 18380K reserved, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff800000 (1520 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80900000 (9184 kB)
[ 0.000000] .init : 0x80c00000 - 0x80d00000 (1024 kB)
[ 0.000000] .data : 0x80d00000 - 0x80d58720 ( 354 kB)
[ 0.000000] .bss : 0x80d5a000 - 0x80dbc4d0 ( 394 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000008] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.000020] Switching to timer-based delay loop, resolution 125ns
[ 0.000345] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000363] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.002057] Console: colour dummy device 80x30
[ 0.002490] console [tty1] enabled
[ 0.002518] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=80000)
[ 0.002549] pid_max: default: 32768 minimum: 301
[ 0.002684] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002707] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003337] CPU: Testing write buffer coherency: ok
[ 0.003981] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.004128] Hierarchical SRCU implementation.
[ 0.004693] smp: Bringing up secondary CPUs ...
[ 0.005470] smp: Brought up 1 node, 2 CPUs
[ 0.005494] SMP: Total of 2 processors activated (32.00 BogoMIPS).
[ 0.005510] CPU: All CPU(s) started in SVC mode.
[ 0.006286] devtmpfs: initialized
[ 0.015814] random: get_random_u32 called from bucket_table_alloc+0x100/0x230 with crng_init=0
[ 0.016243] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.016511] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.016550] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.025850] pinctrl core: initialized pinctrl subsystem
[ 0.026829] NET: Registered protocol family 16
[ 0.032506] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.033504] cpuidle: using governor menu
[ 0.040207] vdd1p0d: supplied by regulator-dummy
[ 0.040684] vdd1p2: supplied by regulator-dummy
[ 0.043045] DDR type is DDR3!
[ 0.050116] imx7d_enet_clk_sel: fec-18: failed to get enet_out clock, assuming ext. clock source
[ 0.050200] imx7d_enet_clk_sel: fec-18: found enet_out clock, assuming internal clock source
[ 0.050345] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.050372] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.050645] imx7d-pinctrl 302c0000.iomuxc-lpsr: initialized IMX pinctrl driver
[ 0.051265] imx7d-pinctrl 30330000.iomuxc: initialized IMX pinctrl driver
[ 0.053364] MU is ready for cross core communication!
[ 0.053586] platform 30800000.aips-bus: coherent DMA mask is unset
[ 0.054108] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.054317] imx rpmsg driver is registered.
[ 0.055131] MU is ready for cross core communication!
[ 0.062367] gpio gpiochip0: names 16 do not match number of GPIOs 32
[ 0.065028] gpio gpiochip2: names 29 do not match number of GPIOs 32
[ 0.066374] gpio gpiochip3: names 24 do not match number of GPIOs 32
[ 0.067687] gpio gpiochip4: names 18 do not match number of GPIOs 32
[ 0.068993] gpio gpiochip5: names 23 do not match number of GPIOs 32
[ 0.070364] gpio gpiochip6: names 15 do not match number of GPIOs 32
[ 0.073281] VCC_USB[1-4]: supplied by 5V
[ 0.073992] SCSI subsystem initialized
[ 0.074212] usbcore: registered new interface driver usbfs
[ 0.074276] usbcore: registered new interface driver hub
[ 0.074379] usbcore: registered new device driver usb
[ 0.074591] usb_phy_generic 30800000.aips-bus:usbphynop1: 30800000.aips-bus:usbphynop1 supply vcc not found, using dummy regulator
[ 0.074922] usb_phy_generic 30800000.aips-bus:usbphynop2: 30800000.aips-bus:usbphynop2 supply vcc not found, using dummy regulator
[ 0.076090] i2c i2c-0: IMX I2C adapter registered
[ 0.076120] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.076756] i2c i2c-3: IMX I2C adapter registered
[ 0.076785] i2c i2c-3: can't use DMA, using PIO instead.
[ 0.076980] Linux video capture interface: v2.00
[ 0.077053] pps_core: LinuxPPS API ver. 1 registered
[ 0.077072] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.077114] PTP clock support registered
[ 0.077357] Advanced Linux Sound Architecture Driver Initialized.
[ 0.078556] clocksource: Switched to clocksource arch_sys_counter
[ 0.078701] VFS: Disk quotas dquot_6.6.0
[ 0.078775] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.086669] NET: Registered protocol family 2
[ 0.087309] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.087378] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.087465] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.087557] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.087601] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.087757] NET: Registered protocol family 1
[ 0.088145] RPC: Registered named UNIX socket transport module.
[ 0.088169] RPC: Registered udp transport module.
[ 0.088183] RPC: Registered tcp transport module.
[ 0.088198] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.090050] Bus freq driver module loaded
[ 0.091088] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.095747] NFS: Registering the id_resolver key type
[ 0.095799] Key type id_resolver registered
[ 0.095815] Key type id_legacy registered
[ 0.095839] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.096346] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.096616] fuse init (API version 7.26)
[ 0.102879] Key type asymmetric registered
[ 0.102932] io scheduler noop registered
[ 0.102948] io scheduler deadline registered
[ 0.103114] io scheduler cfq registered (default)
[ 0.103135] io scheduler mq-deadline registered
[ 0.103151] io scheduler kyber registered
[ 0.106642] mxsfb 30730000.lcdif: 30730000.lcdif supply lcd not found, using dummy regulator
[ 0.106853] mxsfb 30730000.lcdif: Using timings from devicetree
[ 0.181100] Console: switching to colour frame buffer device 100x30
[ 0.200720] mxsfb 30730000.lcdif: initialized
[ 0.204614] mxs-dma 33000000.dma-apbh: initialized
[ 0.208729] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 52, base_baud = 1500000) is a IMX
[ 0.996091] console [ttymxc0] enabled
[ 1.002145] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 53, base_baud = 1500000) is a IMX
[ 1.020541] loop: module loaded
[ 1.045365] random: fast init done
[ 1.052087] nand: device found, Manufacturer ID: 0xc2, Chip ID: 0xdc
[ 1.060358] nand: Macronix MX30LF4G28AC
[ 1.066035] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 112
[ 1.075971] gpmi-nand 33002000.gpmi-nand: mode:5 ,failed in set feature.
[ 1.085551] Bad block table not found for chip 0
[ 1.092924] Bad block table not found for chip 0
[ 1.099443] Scanning device for bad blocks
[ 1.110631] Bad eraseblock 57 at 0x000000720000
[ 1.145486] Bad eraseblock 378 at 0x000002f40000
[ 1.153262] Bad eraseblock 392 at 0x000003100000
[ 1.170515] Bad eraseblock 512 at 0x000004000000
[ 1.248309] Bad eraseblock 1320 at 0x00000a500000
[ 1.261865] Bad eraseblock 1400 at 0x00000af00000
[ 1.370363] Bad eraseblock 2546 at 0x000013e40000
[ 1.480615] Bad eraseblock 3718 at 0x00001d0c0000
[ 1.521755] Bad block table written to 0x00001ffe0000, version 0x01
[ 1.531175] Bad block table written to 0x00001ffc0000, version 0x01
[ 1.539119] 5 ofpart partitions found on MTD device gpmi-nand
[ 1.546460] Creating 5 MTD partitions on "gpmi-nand":
[ 1.553139] 0x000000000000-0x000000080000 : "mx7-bcb"
[ 1.560123] 0x000000080000-0x000000200000 : "u-boot1"
[ 1.566953] 0x000000200000-0x000000380000 : "u-boot2"
[ 1.573690] 0x000000380000-0x000000400000 : "u-boot-env"
[ 1.580575] 0x000000400000-0x000020000000 : "ubi"
[ 1.591945] gpmi-nand 33002000.gpmi-nand: driver registered.
[ 1.600512] libphy: Fixed MDIO Bus: probed
[ 1.607864] pps pps0: new PPS source ptp0
[ 1.615835] libphy: fec_enet_mii_bus: probed
[ 1.622736] fec 30be0000.ethernet eth0: registered PHC device 0
[ 1.630135] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.637915] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.644707] usbcore: registered new interface driver usb-storage
[ 1.652163] usbcore: registered new interface driver usbserial
[ 1.659347] usbcore: registered new interface driver usbserial_generic
[ 1.667181] usbserial: USB Serial support registered for generic
[ 1.674575] usbcore: registered new interface driver cp210x
[ 1.681558] usbserial: USB Serial support registered for cp210x
[ 1.688955] usbcore: registered new interface driver ftdi_sio
[ 1.696198] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.705128] usbcore: registered new interface driver pl2303
[ 1.712299] usbserial: USB Serial support registered for pl2303
[ 1.720919] usbmisc_imx 30b10200.usbmisc: 30b10200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.734479] usbmisc_imx 30b30200.usbmisc: 30b30200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.748380] usbmisc_imx 30b20200.usbmisc: 30b20200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.766572] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.773668] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.808597] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.816977] hub 1-0:1.0: USB hub found
[ 1.822947] hub 1-0:1.0: 1 port detected
[ 1.833163] input: AD7879 Touchscreen as /devices/soc0/soc/30800000.aips-bus/30a20000.i2c/i2c-0/0-002c/input/input0
[ 1.852950] rtc-ds1307 3-0068: registered as rtc0
[ 1.860465] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc1
[ 1.869063] i2c /dev entries driver
[ 1.875316] IR NEC protocol handler initialized
[ 1.882182] IR RC5(x/sz) protocol handler initialized
[ 1.889527] IR RC6 protocol handler initialized
[ 1.896308] IR JVC protocol handler initialized
[ 1.903041] IR Sony protocol handler initialized
[ 1.909853] IR SANYO protocol handler initialized
[ 1.916699] IR Sharp protocol handler initialized
[ 1.923483] IR MCE Keyboard/mouse protocol handler initialized
[ 1.931419] IR XMP protocol handler initialized
[ 1.940103] imx2-wdt 30280000.wdog: timeout 60 sec (nowayout=0)
[ 1.949561] sdhci: Secure Digital Host Controller Interface driver
[ 1.957706] sdhci: Copyright(c) Pierre Ossman
[ 1.963973] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.972522] sdhci-esdhc-imx 30b40000.usdhc: Got CD GPIO
[ 2.038732] mmc0: SDHCI controller on 30b40000.usdhc [30b40000.usdhc] using ADMA
[ 2.054065] caam 30900000.caam: ERA source: CCBVID.
[ 2.061820] caam 30900000.caam: device ID = 0x0a16030000000000 (Era 8)
[ 2.069881] caam 30900000.caam: job rings = 3, qi = 0, dpaa2 = no
[ 2.080948] caam_jr 30901000.jr0: Entropy delay = 3200
[ 2.131760] mmc0: new high speed SD card at address 0001
[ 2.139203] mmcblk0: mmc0:0001 1.88 GiB
[ 2.145851] mmcblk0: p1
[ 2.149778] caam_jr 30901000.jr0: Instantiated RNG4 SH0.
[ 2.198574] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.206447] caam_jr 30901000.jr0: Instantiated RNG4 SH1.
[ 2.219113] caam algorithms registered in /proc/crypto
[ 2.228859] caam_jr 30901000.jr0: registering rng-caam
[ 2.235647] caam 30900000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.245310] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.252450] usbcore: registered new interface driver usbhid
[ 2.259524] usbhid: USB HID core driver
[ 2.269127] coresight-etm3x 3007c000.etm: ETM 3.5 initialized
[ 2.276717] coresight-etm3x 3007d000.etm: ETM 3.5 initialized
[ 2.286395] Netfilter messages via NETLINK v0.30.
[ 2.292627] nfnl_acct: registering with nfnetlink.
[ 2.299007] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
[ 2.306667] nf_tables: (c) 2007-2009 Patrick McHardy <kaber@trash.net>
[ 2.314986] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.322348] NET: Registered protocol family 10
[ 2.329148] Segment Routing with IPv6
[ 2.334265] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.341191] NET: Registered protocol family 17
[ 2.347086] Bridge firewalling registered
[ 2.352541] 8021q: 802.1Q VLAN Support v1.8
[ 2.358264] Key type dns_resolver registered
[ 2.370260] Registering SWP/SWPB emulation handler
[ 2.376929] registered taskstats version 1
[ 2.408235] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.414614] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.423550] hub 1-1:1.0: USB hub found
[ 2.428901] hub 1-1:1.0: 4 ports detected
[ 2.448629] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.456004] hub 2-0:1.0: USB hub found
[ 2.461090] hub 2-0:1.0: 1 port detected
[ 2.467428] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 2.482517] imx_thermal 30000000.aips-bus:tempmon: Extended Commercial CPU temperature grade - max:105C critical:105C passive:95C
[ 2.498587] ubi0: default fastmap pool size: 200
[ 2.504719] ubi0: default fastmap WL pool size: 100
[ 2.511088] ubi0: attaching mtd4
[ 2.545276] random: crng init done
[ 2.739706] ubi0: attached by fastmap
[ 2.745139] ubi0: fastmap pool size: 200
[ 2.748621] usb 1-1.1: new low-speed USB device number 3 using ci_hdrc
[ 2.750820] ubi0: fastmap WL pool size: 100
[ 2.784078] ubi0: attached mtd4 (name "ubi", size 508 MiB)
[ 2.791421] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.800180] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.808870] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.817735] ubi0: good PEBs: 4052, bad PEBs: 12, corrupted PEBs: 0
[ 2.825878] ubi0: user volume: 4, internal volumes: 1, max. volumes count: 128
[ 2.835101] ubi0: max/mean erase counter: 97/38, WL threshold: 4096, image sequence number: 1382589019
[ 2.848401] ubi0: available PEBs: 0, total reserved PEBs: 4052, PEBs reserved for bad PEB handling: 68
[ 2.862007] ubi0: background thread "ubi_bgt0d" started, PID 156
[ 2.863029] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 2.882204] rtc-ds1307 3-0068: setting system clock to 2020-12-15 20:02:19 UTC (1608062539)
[ 2.893347] ALSA device list:
[ 2.898078] No soundcards found.
[ 2.929085] input: HID 046a:0001 as /devices/soc0/soc/30800000.aips-bus/30b20000.usb/ci_hdrc.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046A:0001.0001/input/input2
[ 2.994264] UBIFS (ubi0:3): recovery needed
[ 3.009139] hid-generic 0003:046A:0001.0001: input,hidraw0: USB HID v1.00 Keyboard [HID 046a:0001] on usb-ci_hdrc.0-1.1/input0
[ 3.108911] UBIFS (ubi0:3): recovery deferred
[ 3.115285] UBIFS (ubi0:3): UBIFS: mounted UBI device 0, volume 3, name "rootfs", R/O mode
[ 3.125596] UBIFS (ubi0:3): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 3.139497] UBIFS (ubi0:3): FS size: 493936640 bytes (471 MiB, 3890 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 3.154377] UBIFS (ubi0:3): reserved for root: 0 bytes (0 KiB)
[ 3.162338] UBIFS (ubi0:3): media format: w4/r0 (latest is w5/r0), UUID 9E00FC6E-6E6C-4B27-BB60-0DDBCBB4EE2A, small LPT model
[ 3.181185] VFS: Mounted root (ubifs filesystem) readonly on device 0:12.
[ 3.192488] devtmpfs: mounted
[ 3.198666] Freeing unused kernel memory: 1024K
[ 3.618602] usb 1-1.3: new high-speed USB device number 4 using ci_hdrc
[ 3.866392] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 3.898848] systemd[1]: Detected architecture arm.
Welcome to TDX X11 2.6-snapshot-20200309 (thud)!
[ 3.953668] systemd[1]: Set hostname to <colibri-imx7>.
[ 4.922456] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.958841] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.992893] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 5.092914] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.129063] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.168832] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 5.201416] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on Journal Socket.
Starting File System Check on Root Device...
Mounting Temporary Directory (/tmp)...
Starting Create list of required st…ce nodes for the current kernel...
Starting Journal Service...
[ OK ] Reached target Remote File Systems.
Mounting Kernel Debug File System...
Starting Load Kernel Modules...
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Reached target Paths.
[ OK ] Listening on udev Control Socket.
Starting udev Coldplug all Devices...
[ OK ] Started Hardware RNG Entropy Gatherer Daemon.
[ OK ] Started Journal Service.
[ OK ] Started File System Check on Root Device.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Load Kernel Modules.
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Mounting FUSE Control File System...
Starting Remount Root and Kernel File Systems...
[ OK ] Mounted Kernel Configuration File System.
[ 6.145139] UBIFS (ubi0:3): completing deferred recovery
[ OK ] Started Apply Kernel Variables.
[ OK ] Mounted FUSE Control File System.
[ OK ] Started udev Coldplug all Devices.
[ 6.290429] UBIFS (ubi0:3): background thread "ubifs_bgt0_3" started, PID 184
[ 6.296538] UBIFS (ubi0:3): deferred recovery completed
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
Starting Create Static Device Nodes in /dev...
[ 6.523011] systemd-journald[170]: Received request to flush runtime journal from PID 1
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Containers.
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Started Network Time Synchronization.
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Reached target System Initialization.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ 7.548129] sgtl5000 0-000a: sgtl5000 revision 0x11
[ OK ] Listening on dropbear.socket.
[ 7.613385] imx-sdma 30bd0000.sdma: no iram assigned, using external mem
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ 7.676033] asoc-simple-card sound: sgtl5000 <-> 308a0000.sai mapping ok
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ 7.738531] spi_imx 30840000.ecspi: probed
[ 7.754611] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ 7.762260] imx-sdma 30bd0000.sdma: loaded firmware 4.2
[ OK ] Reached target Basic System.
[ OK ] Started Timestamping service.
[ 7.831143] uvcvideo: Found UVC 1.00 device USB 2.0 PC Cam (090c:037c)
[ 7.846278] input: USB 2.0 PC Cam as /devices/soc0/soc/30800000.aips-bus/30b20000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input3
[ OK ] Started D-Bus [ 7.864260] usbcore: registered new interface driver uvcvideo
System Message Bus.
[ 7.872332] USB Video Class driver (1.1.1)
Starting Connection service...
[ OK ] Started Xserver startup without a display manager.
Starting Load default USB gadget schema g1.schema...
[ OK ] Started System Logging Service.
Starting Telephony service...
Starting Login Service...
[ OK ] Started Kernel Logging Service.
Starting RPC Bind Service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Reached target System Time Synchronized.
[ OK ] Found device /dev/ttymxc0.
[ 8.567629] using random self ethernet address
[ 8.573788] using random host ethernet address
[ 8.949902] CAN device driver interface
[ OK ] Started RPC Bind Service.
[ 9.066078] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 9.066594] mcp251x spi2.0 can0: MCP2515 successfully initialized.
[ 9.076898] usb0: MAC 00:14:2d:ff:ff:ff
[ OK ] Started Load default USB gadget schema g1.schema.
Starting Save/Restore Sound Card State...
Starting Network Service...
[ 9.682692] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
[ OK ] Started Connection service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Login Service.
[ OK ] Started Telephony service.
[ OK ] Started Network Service.
[ OK ] Reached target Network.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
Starting Permit User Sessions...
[ 10.514861] Bluetooth: Core ver 2.22
[ 10.525149] NET: Registered protocol family 31
[ 10.531739] Bluetooth: HCI device and connection manager initialized
[ 10.540558] Bluetooth: HCI socket layer initialized
[ 10.547781] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 10.548031] Bluetooth: L2CAP socket layer initialized
[ 10.562930] Bluetooth: SCO socket layer initialized
[ OK ] Started Permit User Sessions.
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttymxc0.
Starting WPA supplicant...
Starting Hostname Service...
[ 10.909110] Micrel KSZ8041 30be0000.ethernet-1:00: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=30be0000.ethernet-1:00, irq=POLL)
[ 10.924759] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ OK ] Started WPA supplicant.
[ OK ] Started Hostname Service.
[ 13.049524] fec 30be0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 13.057484] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
