On LXTerminal when sudo adduser user dialout command is entered
Output is - sudo:command not found
And LXTerminal shows ‘sh-4.4#’
Hi
In all our demo images you are logged in as user root without a password.
Thus one does not need to use sudo at all and consequently sudo is not installed in any of our images.
Max
(Refer to “EXTRA_IMAGE_FEATURES” in build/conf/local.conf should you want to influence this for your own openembedded builds)
