LVDS with mallow Carrier Board
I’m using the Verdin iMX 8M Plus with the Mallow carrier board, trying to get a 10-inch LVDS display from Toradex working. I’m running a customized Yocto image and have added the following overlays:
cat /boot/overlays.txt
fdt_overlays=verdin-imx8mp_panel-cap-touch-10inch-lvds_overlay.dtbo verdin-imx8mp_spidev_overlay.dtbo
However, I’m encountering errors in the dmesg output related to the LVDS display:
[ 0.318092] platform 32c00000.bus:ldb@32ec005c: Fixing up cyclic dependency with panel-lvds-native
[ 1.462658] pwm-backlight backlight-lvds-native: supply power not found, using dummy regulator
Any guidance on resolving these errors or configuring the LVDS setup correctly would be greatly appreciated!
Based on the context provided, here are some steps you can take to resolve the issues with your LVDS display setup on the Verdin iMX 8M Plus with the Mallow carrier board:
  1. Cyclic Dependency:
    • Review the device tree overlays you are using, specifically verdin-imx8mp_panel-cap-touch-10inch-lvds_overlay.dtbo and verdin-imx8mp_spidev_overlay.dtbo. Check for any circular references or misconfigurations that could be causing the cyclic dependency error. You may need to adjust the order of the overlays or modify their definitions to resolve the conflict.
  2. Missing Power Supply:
    • Verify that the power supply for the backlight is correctly defined in the device tree. Ensure that the necessary power regulators are specified and that the connections are properly made on the Mallow carrier board. The warning about using a dummy regulator suggests that the system cannot find the specified power supply, so double-check the device tree configuration for any missing or incorrect entries related to the backlight power supply.
  3. Consult Documentation:
    • Refer to the Toradex documentation for the specific LVDS display and the Mallow carrier board. This may provide insights into required configurations and troubleshooting steps that are specific to your hardware setup.
  4. Examine dmesg Output:
    • Continue to monitor the dmesg output for any additional error messages that may provide further clues about the configuration issues. Addressing these messages systematically can help in resolving the overall setup problems.
By following these recommendations, you should be able to address the errors and configure the LVDS display correctly.
How to activate the LVDS touch panel for Verdin iMX8M Mini on Yocto.
Hi @Seyad!
As I said in this topic, the jumper JP1 must be closed. If it is open, the backlight converter will not be powered, and you’ll see nothing on the display.
Could you test it, please?
Best regards.
Lucas Azeituno
Thank you for your help! @lucas_az.tx I finally found the issue. I had used a 24-volt power supply for the Mallow carrier board, which was directly passed to the display, causing it not to work. After switching to a 12-volt power supply, everything is now working fine.
Hi @Seyad!
I’m glad to hear that it worked.
Best regards.
Lucas Azeituno
