Ive managed to get my lvds screen to work with my embedded board but am having an issue with the image.
It looks every every odd (1,3,5 etc.) vertical line is in its correct position while every even vertical line is offset to the right by about 15 pixels.
I have contacted the distributor of the screen and have confirmed all the relevant variables in the dtsi file.
Attached is a picture of the issue along with my dtsi file.
I remember we talked about this over the phone and you resolved it due to wrong timings on your datasheet. If everything is resolved could you mark this as answered, thank you.
The problem was that I had the HDMI and LVDS connected at the same time. As soon as I disconnected the HDMI cable from the embedded device, the problem was fixed.
