LVDS overlays on TorizonCore 5.7 and TorizonCore 6.3
Hi all,
I have IMX8QM on Ixora Board V1.2 running TorizonCore 5.7 where I enable the following overlays to enable a 10.1" LVDS display from Toradex:
fdt_overlays=apalis-imx8_lvds_overlay.dtbo apalis-imx8_atmel-mxt_overlay.dtbo display-lt170410_overlay.dtbo
The above line in the overlays.txt file only enables the picture on the display but not the touch.
In parallel, I have another IMX8QM on Ixora Board V.12 running ToradexCore 6.3 where I enable the following overlays to enable the same 10.1" LVDS display from Toradex:
fdt_overlays=apalis-imx8_panel-cap-touch-10inch-lvds_overlay.dtbo apalis-imx8_spi1_spidev_overlay.dtbo apalis-imx8_spi2_spidev_overlay.dtbo
The above line in the overlays.txt file enables both the picture and the touch.
Can you please help me to understand what am I doing wrong on the 1st SBC running 5.7, so hat the touch is not working?
Thank you in advance
Samir
Greetings @hajili,
I just tested this on our TorizonCore 5.7.2 image on Apalis i.MX8 and it works fine for me. I applied the same overlays as you did here and both the display and touch just work.
Perhaps there’s a connection issue or something similar on your 5.7 board?
Do you see any logs in dmesg related to the touch interface, that might hint to something being wrong?
