LVDS/DSI and EDID
The Toradex documentation makes reference to the fact that LVDS and DSI support EDID/DDC for display resolutions, but comment that the typical use case is to hard code this information in the device tree.
Can you recommend any resources/information on how one might actually support EDID “in hardware” for these interfaces? I know for HDMI there is an embedded I2C channel used to read the data from an EEPROM - how is this set up/designated for say, an LVDS or DSI display, assuming that is even possible?
Or, is this just referring to that it’s possible to “inject” an EDID blob via the kernel command line, and there is no capability to have (say) a display adapter board with an EEPROM that can be read automatically and allow for auto-setting of resolution?
Thanks!
Hardware EDID Support for LVDS and DSI Displays
Based on the Toradex documentation, EDID support varies significantly between different display interfaces and modules.
HDMI EDID Support
For HDMI interfaces, EDID is fully supported in hardware(1). The documentation states that “a connected monitor provides the modes it is capable of displaying and its preferred mode through DDC/EDID”(1). No configuration is needed as “the kernel then decides on the mode depending on the capabilities of the monitor and the SoM”(1).
LVDS EDID Implementation
For LVDS displays, the documentation indicates that EDID support exists but is typically not used in practice(1). The documentation notes that LVDS “Supports EDID (Software)” but clarifies that “the common use case is to hard-code the mode information in the device-tree/panel-driver or the overlay”(1).
However, there is evidence that hardware EDID can be implemented for LVDS. The SMARC module design guide provides detailed information about implementing EDID EEPROM for LVDS displays. It explains that EDID data can be stored in an EEPROM accessed via I2C, and this EEPROM may reside either on the display assembly or elsewhere in the path between the SoC and display.
The implementation requires:
  • An I2C interface (I2C_LCD) between the module and display
  • Level translation (typically 3.3V levels for the display)
  • An EDID EEPROM at I2C address 0x50
DSI EDID Support
For DSI displays on modules like Verdin iMX8M Plus, the documentation shows that DSI-to-HDMI adapters support EDID(1), but direct DSI panel connections typically require hardcoded timing information in device tree overlays(1).
Practical Implementation
The documentation suggests that while hardware EDID is theoretically possible for LVDS and some DSI configurations, the standard practice is device tree configuration because:
  1. Complexity: Hardware EDID requires additional I2C infrastructure and level translation
  2. Reliability: Hardcoded timings in device trees are more predictable
  3. Cost: Adding EDID EEPROM increases BOM cost
For LVDS specifically, if you want to implement hardware EDID, you would need to:
  • Include the I2C_LCD interface in your carrier board design
  • Add level translation circuitry (back-to-back FETs or dedicated buffer like FXMA2102)
  • Include an EDID EEPROM (such as AT24HC02) at I2C address 0x50
  • Ensure your display timing software can read and interpret the EDID data
Recommendation
For most applications, Toradex recommends using device tree overlays to specify display timings rather than implementing hardware EDID for LVDS and DSI interfaces(1). This approach is more reliable, cost-effective, and easier to debug than hardware EDID implementations.
Hi @bw908 ,
how was the AI answer for you there?
Thanks Michael,
The AI answer was a helpful sanity-check on what’s involved hardware-wise.
Software-wise I skimmed the 8MP LCDIFv3 driver code, and since the same underlying silicon implementation is driving all three display interfaces (HDMI, DSI, LVDS), it seems the driver should support DDC either as-is on all interfaces or with only minimal modification. We do intend to move forward and at least try to get this working as a means to future-proof against display lifecycle EoL (which in our past experience, is usually shorter than the lifecycle of our products).
Just to follow up… turns out I had been looking at imx-ldb.c which is the LDB driver for the imx6 and earlier, rather than imx8mp-ldb.c.
The latter doesn’t embed any sort of DDC support and via HDMI this is achieved as a property of the hdmi_connector node instead.
However, I was successful in taking the lvds-panel driver code and combining it with portions of panel-simple.c that incorporate EDID probing as a proof of concept for LVDS. Together with the drm.edid_firmware overload in the kernel, I was able to get Weston to start without any manually specified timings in the DTS.
panel-simple already has some EDID capability, so likely this aspect may “just work” out of the box for a basic DSI panel, although this is often complicated by such panels requiring “magic” undocumented initialization processes.
