Hello Toradex team,
I hope you are all doing great! And thank you for your support.
Hardware:
- SoM Verdin IMX8M Plus Quad 4GB WB IT v1.1A
- Heatsink Verdin Industrial Heatsink Type 1 V1.0B
- Dual-Band Wi-Fi/Bluetooth PCB Antenna 100mm V1.0A
- Custom Carrier Board based on Verdin
uname:
- Linux verdin-imx8mp-14777482 5.15.129-6.4.0+git.67c3153d20ff #1-TorizonCore SMP PREEMPT Wed Sep 27 12:30:36 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
Images tested:
- torizon-core-docker-verdin-imx8mp-Tezi_6.4.0+build.5.tar (STABLE Release)
Guest OS:
- macOS (M1 Pro ARM64)
- Linux ubuntu (VM x86_64)
Issue:
I was reviewing my console and I saw this message on all my devices, and I believe that is related to a white flash on the display, first at boot time then when the user space come to live.
I have the following device tree for the lvds
panel:
panel_lvds: panel-lvds {
compatible = "panel-lvds";
backlight = <&backlight>;
power-supply = <®_5p0v>;
data-mapping = "vesa-24";
height-mm = <528>;
width-mm = <297>;
panel-timing {
clock-frequency = <148500000>;
hactive = <1920>;
hback-porch = <0>;
hfront-porch = <130>;
hsync-len = <10>;
hsync-active = <0>;
vactive = <1080>;
vback-porch = <0>;
vfront-porch = <35>;
vsync-len = <10>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
Here is the output of the console:
[ 12.145230] ------------[ cut here ]------------
[ 12.145246] WARNING: CPU: 3 PID: 103 at lcdifv3_set_mode+0x90/0x2f0
[ 12.145263] Modules linked in: xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xfrm_user iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter ip_ta
bles x_tables br_netfilter bridge stp llc qmi_wwan cdc_wdm usbnet option usb_wwan overlay mwifiex_sdio mwifiex cfg80211 crct10dif_ce lm75 hci_uart btqca imx_sdma pinctrl_mcp23s08_i2c btbcm pinctrl_mcp23s08 ti_ads1015 btinte
l industrialio_triggered_buffer kfifo_buf industrialio fsl_jr_uio secvio uio_pdrv_genirq uio joydev egalax_i2c(O) libcomposite galcore(O) fuse lontium_lt8912b ti_sn65dsi83 sec_mipi_dsim_imx display_connector sec_dsim
[ 12.145392] CPU: 3 PID: 103 Comm: kworker/u8:2 Tainted: G O 5.15.129-6.4.0+git.67c3153d20ff #1-TorizonCore
[ 12.145399] Hardware name: iMX8M Plus on GSF Board (DT)
[ 12.145403] Workqueue: events_unbound commit_work
[ 12.145412] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 12.145418] pc : lcdifv3_set_mode+0x90/0x2f0
[ 12.145423] lr : lcdifv3_set_mode+0x1bc/0x2f0
[ 12.145428] sp : ffff80000a6cbc60
[ 12.145430] x29: ffff80000a6cbc60 x28: 0000000000000000 x27: 0000000000000000
[ 12.145439] x26: ffff80000a1d5280 x25: ffff0000c001c005 x24: ffff80000936b568
[ 12.145448] x23: 0000000000000038 x22: ffff0000c4fd4580 x21: ffff80000a0654c0
[ 12.145457] x20: ffff0000c4fd5f80 x19: ffff80000a6cbc98 x18: 0000000000016000
[ 12.145466] x17: 0000000000000000 x16: 0000000000000000 x15: 0000003569ed534a
[ 12.145474] x14: 0000000000000354 x13: 0000000000000001 x12: 0000000000000000
[ 12.145483] x11: 000000003df582e0 x10: 0000000000000009 x9 : 000000003df582e0
[ 12.145492] x8 : 0000000000000010 x7 : 0000000000000000 x6 : 00000000076181c9
[ 12.145501] x5 : 00000000000000c0 x4 : 000000000100f100 x3 : 0000000000000000
[ 12.145509] x2 : 0000000000000000 x1 : ffff80000ba30014 x0 : 0000000004380780
[ 12.145519] Call trace:
[ 12.145522] lcdifv3_set_mode+0x90/0x2f0
[ 12.145527] lcdifv3_crtc_atomic_enable+0x88/0xdc
[ 12.145538] drm_atomic_helper_commit_modeset_enables+0x200/0x24c
[ 12.145544] lcdifv3_drm_atomic_commit_tail+0x30/0x70
[ 12.145550] commit_tail+0xa4/0x1b0
[ 12.145555] commit_work+0x14/0x20
[ 12.145560] process_one_work+0x1d4/0x4a0
[ 12.145567] worker_thread+0x13c/0x490
[ 12.145572] kthread+0x150/0x160
[ 12.145579] ret_from_fork+0x10/0x20
[ 12.145587] ---[ end trace bc2a54e61e0360c6 ]---
[ 12.145616] ------------[ cut here ]------------
[ 12.145619] WARNING: CPU: 3 PID: 103 at lcdifv3_set_mode+0xb4/0x2f0
[ 12.145627] Modules linked in: xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE nf_conntrack_netlink nfnetlink xfrm_user iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c xt_addrtype iptable_filter ip_ta
[ 12.145756] CPU: 3 PID: 103 Comm: kworker/u8:2 Tainted: G W O 5.15.129-6.4.0+git.67c3153d20ff #1-TorizonCore
[ 12.145765] Hardware name: iMX8M Plus on GSF Board (DT)
[ 12.145770] Workqueue: events_unbound commit_work
[ 12.145779] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 12.145785] pc : lcdifv3_set_mode+0xb4/0x2f0
[ 12.145790] lr : lcdifv3_set_mode+0x1bc/0x2f0
[ 12.145795] sp : ffff80000a6cbc60
[ 12.145797] x29: ffff80000a6cbc60 x28: 0000000000000000 x27: 0000000000000000
[ 12.145806] x26: ffff80000a1d5280 x25: ffff0000c001c005 x24: ffff80000936b568
[ 12.145815] x23: 0000000000000038 x22: ffff0000c4fd4580 x21: ffff80000a0654c0
[ 12.145824] x20: ffff0000c4fd5f80 x19: ffff80000a6cbc98 x18: 0000000000016000
[ 12.145833] x17: 0000000000000000 x16: 0000000000000000 x15: 0000003569ed534a
[ 12.145841] x14: 0000000000000354 x13: 0000000000000001 x12: 0000000000000000
[ 12.145850] x11: 000000003df582e0 x10: 0000000000000009 x9 : 000000003df582e0
[ 12.145859] x8 : 0000000000000010 x7 : 0000000000000000 x6 : 00000000076181c9
[ 12.145867] x5 : 00000000000000c0 x4 : 000000000100f100 x3 : 0000000000000000
[ 12.145875] x2 : 0000000000000000 x1 : ffff80000ba30018 x0 : 0000000000000082
[ 12.145887] Call trace:
[ 12.145892] lcdifv3_set_mode+0xb4/0x2f0
[ 12.145903] lcdifv3_crtc_atomic_enable+0x88/0xdc
[ 12.145913] drm_atomic_helper_commit_modeset_enables+0x200/0x24c
[ 12.145919] lcdifv3_drm_atomic_commit_tail+0x30/0x70
[ 12.145926] commit_tail+0xa4/0x1b0
[ 12.145932] commit_work+0x14/0x20
[ 12.145936] process_one_work+0x1d4/0x4a0
[ 12.145943] worker_thread+0x13c/0x490
[ 12.145948] kthread+0x150/0x160
[ 12.145955] ret_from_fork+0x10/0x20
[ 12.145962] ---[ end trace bc2a54e61e0360c7 ]---
I hope we will be able to find a solution to my problem.
M
