I have a 10 inch LVDS display connected to the Colibri iMX8DX via connector X2 (30 pin FFC). I followed the document “Qt Debian Container for Torizon” and executing QT5 containers through portainer. I get no image on the LVDS display. I installed “imx8qxp-colibri-lvds-single-eval-v3.dts” via Torizon Core Builder. It appears the LVDS signals from the Colibri are not activated.
How exactly your LVDS display is connected? Have you checked LVDS signals by connecting a scope or just assume that LVDS signals are not activated because display is blank?.
I determined the LVDS signal are not active by using an oscilloscope, there is no LVDS data or LVDS clock. I’m using X2 located on bottom side of Colibri IMX8 to connect to the display.
I have proven the setup i’m using is good. Using a Colibri iMX8DX 1GB version 1.0B with the same display, cable, carrier board, etc I can display a custom image someone created using Qt with C++. The connection to the display is also with X2 located on the bottom of the Colibri. The clock and data signals show as expected on an oscilloscope.
Again, my intent is to get an image on the 10 inch LVDS display following the steps in “Qt Debian Container for Torizon” using Colibri IMX8DX, 1 GB version 1.0D. What device tree should i use for the 10 inch LVDS display? Is there anything else that would be different that i need to consider?
There’s a table too on the page that shows which overlays are needed for which display. Just do double-check that the kernel version matches, otherwise the overlay may not apply cleanly.
