LVDS Configuration for EMC
We have a custom board based on the iMX8MP and that uses a native LVDS touchscreen. It runs Torizon OS with a GUI. Some EMC testing was done and apparently the LVDS is responsible for a large part of the noise.
Is there anything we can do with the device tree to reduce the noise ?
  • Custom board dtsi (used with imx8mp-verdin.dtsi and imx8mp-verdin-wifi.dtsi):
&backlight {
	power-supply = <&reg_3p3v>;
/* EEPROM on Mallow */
&eeprom_carrier_board {
/* Verdin ETH_1 */
&eqos {
/* Verdin I2C_2_DSI */
&i2c2 {
/* Verdin I2C_4_CSI */
&i2c3 {
/* Verdin I2C_1 */
&i2c4 {
	/* Audio Codec */
	nau8822_1a: audio-codec@1a {
		compatible = "nuvoton,nau8822";
		reg = <0x1a>;
		pinctrl-names = "default";
		pinctrl-0 = <&pinctrl_sai1>;
		#sound-dai-cells = <0>;
/* Verdin PCIE_1 */
&pcie {
&pcie_phy {
/* Verdin PWM_1 */
&pwm1 {
/* Verdin PWM_2 */
&pwm2 {
/* Verdin PWM_3_DSI */
&pwm3 {
/* Verdin I2S_1 */
&sai1 {
	assigned-clocks = <&clk IMX8MP_CLK_SAI1>;
	assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
	assigned-clock-rates = <24576000>;
	fsl,sai-mclk-direction-output;
/* Verdin UART_1 */
&uart1 {
/* Verdin UART_2 */
&uart2 {
/* Verdin UART_3 */
&uart3 {
/* Verdin USB_1 */
&usb3_0 {
&usb3_phy0 {
/* Verdin USB_2 */
&usb3_1 {
&usb3_phy1 {
  • Panel display overlay:
/dts-v1/;
/plugin/;
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/pwm/pwm.h>
#include <imx8mp-pinfunc.h>
	compatible = "toradex,verdin-imx8mp";
	backlight_lvds_native: backlight-lvds-native {
		compatible = "pwm-backlight";
		pinctrl-0 = <&pinctrl_i2s_2_d_out_dsi_1_bkl_en>;
		brightness-levels = <0 45 63 88 119 158 203 255>;
		default-brightness-level = <4>;
		/* Verdin I2S_2_D_OUT as GPIO (SODIMM 46) */
		enable-gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>;
		/* Verdin PWM_2 (SODIMM 16) */
		pwms = <&pwm2 0 6666667 PWM_POLARITY_INVERTED>;
	panel-lvds-native {
		compatible = "panel-lvds";
		backlight = <&backlight_lvds_native>;
		data-mapping = "vesa-24";
		height-mm = <86>;
		width-mm = <154>;
		/* Verdin I2S_2_BCLK as GPIO (SODIMM 42) */
		pinctrl-0 = <&pinctrl_i2s_2_bclk_touch_reset>;
		reset-gpios = <&gpio5 0 GPIO_ACTIVE_HIGH>;
		panel-timing {
			clock-frequency = <44900000 51200000 63000000>;
			de-active = <1>;
			hactive = <1024>;
			hback-porch = <160>;
			hfront-porch = <16 160 216>;
            hsync-active = <0>;
			hsync-len = <1 70 140>;
			pixelclk-active = <1>; /* positive edge */
			vactive = <600>;
			vback-porch = <23>;
			vfront-porch = <1 12 127>;
            vsync-active = <0>;
			vsync-len = <1 10 20>;
		port {
			panel_lvds_native_in: endpoint {
				remote-endpoint = <&lvds_out>;
&gpu_2d {
&gpu_3d {
// On Mallow, I2C_2_DSI (&i2c2) is used, On Custom I2C_1 (&i2c4)
&i2c4 {
    // Pin 44 (SAI3_TXFS, GPIO4_IO31) > INT_TOUCH#
    // Pin 48 (SAI3_RXD, GPIO4_IO30) > RST_TOUCH#
    touchscreen@41 {
        compatible = "ilitek,ili251x";
        reg = <0x41>;
		pinctrl-0 = <&pinctrl_i2s_2_d_in_gpio>,
			    <&pinctrl_i2s_2_sync_gpio>;
		/* Verdin I2S_2_SYNC as GPIO (SODIMM 44) */
        interrupt-parent = <&gpio4>;
        interrupts = <31 IRQ_TYPE_EDGE_FALLING>;
		/* Verdin I2S_2_D_IN as GPIO (SODIMM 48) */
        reset-gpios = <&gpio4 30 GPIO_ACTIVE_LOW>;
&lcdif2 {
&ldb {
    lvds-channel@0 {
        fsl,data-mapping = "vesa-24";
        fsl,data-width = <24>;
        port@1 {
            reg = <1>;
            lvds_out: endpoint {
                remote-endpoint = <&panel_lvds_native_in>;
&ldb_phy {
&mix_gpu_ml {
&ml_vipsi {
/* Verdin PWM_2 */
&pwm2 {
&iomuxc {
	pinctrl_i2s_2_d_in_gpio: gpio4io30grp {
		fsl,pins =
			<MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x1c4>;	/* SODIMM 48 */
	pinctrl_i2s_2_sync_gpio: gpio4io31grp {
		fsl,pins =
			<MX8MP_IOMUXC_SAI3_TXFS__GPIO4_IO31 0x184>;	/* SODIMM 44 */
  • LVDS-relevant DTS configuration found in imx8mp-related device trees:
	lvds_ti_sn65dsi84: bridge@2c {
		compatible = "ti,sn65dsi84";
		/* Verdin GPIO_9_DSI (SN65DSI84 IRQ, SODIMM 17, unused) */
		/* Verdin GPIO_10_DSI (SODIMM 21) */
		enable-gpios = <&gpio4 28 GPIO_ACTIVE_HIGH>;
		pinctrl-0 = <&pinctrl_gpio_10_dsi>;
		reg = <0x2c>;
		status = "disabled";
	ldb: ldb-display-controller {
		#address-cells = <1>;
		#size-cells = <0>;
		compatible = "fsl,imx8mp-ldb";
		clocks = <&clk IMX8MP_CLK_MEDIA_LDB_ROOT>;
		clock-names = "ldb";
		assigned-clocks = <&clk IMX8MP_CLK_MEDIA_LDB>;
		assigned-clock-parents = <&clk IMX8MP_VIDEO_PLL1_OUT>;
		gpr = <&media_blk_ctrl>;
		power-domains = <&pgc_mediamix>;
		lvds-channel@0 {
			#size-cells = <0>;
			reg = <0>;
			phys = <&ldb_phy1>;
			phy-names = "ldb_phy";
			port@0 {
				reg = <0>;
				ldb_ch0: endpoint {
					remote-endpoint = <&lcdif2_disp_ldb_ch0>;
		lvds-channel@1 {
			reg = <1>;
			phys = <&ldb_phy2>;
			port {
				ldb_ch1: endpoint {
					remote-endpoint = <&lcdif2_disp_ldb_ch1>;
	ldb_phy: phy-lvds {
		compatible = "fsl,imx8mp-lvds-phy";
		#size-cells = <0>;
		clocks = <&clk IMX8MP_CLK_MEDIA_APB_ROOT>;
		clock-names = "apb";
		ldb_phy1: port@0 {
			reg = <0>;
			#phy-cells = <0>;
		ldb_phy2: port@1 {
			reg = <1>;
			#phy-cells = <0>;
Thank you for your support.
EMC Noise Reduction for LVDS Display
While the available documentation doesn’t provide specific Device Tree parameters for reducing LVDS EMC noise, I can offer some general approaches based on Toradex’s Device Tree customization capabilities.
Device Tree Customization Approach
According to Toradex documentation, Device Tree modifications can be used to customize hardware configurations (1). For your LVDS noise issue, you can leverage Device Tree Overlays to modify display parameters (2).
Potential Device Tree Modifications
Based on your current configuration, consider these adjustments in your panel overlay:
1. Clock Frequency Optimization
Your current panel timing uses a wide clock frequency range:
Try using a more specific, lower frequency to reduce EMI:
clock-frequency = <44900000>;
2. Drive Strength Adjustments
Modify the pin configuration drive strength in your pinctrl definitions. Lower drive strength can reduce noise:
    fsl,pins =
        <MX8MP_IOMUXC_SAI3_RXD__GPIO4_IO30 0x104>;  /* Reduced drive strength */
3. LVDS PHY Configuration
Consider adding specific LVDS PHY properties to your overlay for better EMC compliance. The documentation shows that LVDS PHY parameters can be configured through the Device Tree (3).
Implementation Process
  1. Use TorizonCore Builder to apply your modified Device Tree overlay (2)
  2. Test systematically - modify one parameter at a time to isolate the most effective changes
  3. Consider pre-built overlays - Check if Toradex provides LVDS overlays that might already include EMC-optimized settings (3)
Additional Considerations
  • Hardware-level solutions may also be necessary (proper grounding, shielding, PCB layout)
  • Display timing parameters (hsync-len, vsync-len, porch values) can also affect EMI characteristics
  • Power supply filtering for the display and backlight circuits
The Device Tree approach allows you to modify these parameters without rebuilding the entire kernel, making it easier to iterate and test different configurations (1).
Hi @mnano,
We have not tested the LVDS spread spectrum for iMX8MP, however we have some customers who enabled it following this thread from NXP: Solved: Re: IMX8MP spread spectrum - NXP Community
Also this thread might be useful for you: LVDS change MEDIA BLK_CTRL - #10 by henrique.tx
