Hello Toradex community,
I’m new in this forum (and also in embedded linux projects). I’m facing a driver problem with my mPCIe LTE module [LE910C4-EU]. The following link shows me how to deal with the device is connected to a Linux distribution :
The command lsusb shows me :
root@apalis-tk1:/sys/devices/platform# lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/2p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=tegra-xhci/6p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-ehci/1p, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-ehci/1p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 1, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 2, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 3, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 4, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 5, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 3, If 6, Class=Vendor Specific Class, Driver=, 480M
This is the dmesg log when I connect the LTE module :
[ 466.391305] usb 1-1: new high-speed USB device number 3 using tegra-ehci
[ 466.550345] usb 1-1: New USB device found, idVendor=1bc7, idProduct=1201
[ 466.567310] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 466.576968] usb 1-1: Product: LE910C4-EU
[ 466.581365] usb 1-1: Manufacturer: Android
[ 466.585755] usb 1-1: SerialNumber: 0123456789ABCDEF
However, the module doesn’t show any interface network from the module when I’m using ip a.
Do I need to recompile the kernel with the cdc_ether driver (instead of tegra-ehci) ?
Thank you for your time.
Regards.
