I want to do a loop back test on ixora v1.1 with can-utils.
Is it enough to simply connect can bus 0 and 1 to each other with a jumper? Do I need some kind of termination circuit?
thanks
rifo
thanks
rifo
Hi
While you violate the CAN specification this has always worked for me.
Max
I connected the Can1_H <-> Can2_H, Can1_L <-> Can2_L
I then used cansend and candump but wasn’t able to receive anything.
root@apalis-imx6:~# cansend imp 18FF2488#01.FF.00.00
interface = imp, family = 29, type = 3, proto = 1
root@apalis-imx6:~# candump tra
interface = tra, family = 29, type = 3, proto = 1
<0x001> [1] 12
root@apalis-imx6:~# ifconfig
imp Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING NOARP MTU:16 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:10
RX bytes:0 (0.0 B) TX bytes:1 (1.0 B)
Interrupt:37
tra Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1 (1.0 B) TX bytes:0 (0.0 B)
Interrupt:36
I will try to add the termination resistors and see what happens. If you have any suggestions please feel free to comment.
seems like I used the cansend incorrectly, below combination works fine.
cansend imp -i 0x18FF2488 0x01 0xFF 0x00 0x10
<0x488> [4] 01 ff 00 10
