When I try to connect my Logitech BRIO webcam to USBH4 port, it’s recognized as a keyboard. I’ve been trying to get access to my webcam inside a Docker container, what can I do to make it visible as a camera?
Also I tried other webcams but I haven’t seen anything related to webcams in logs from Docker containers and in case of camera access in the browser my webcams were not found.
Logitech BRIO is a UVC device according to this resource,
sudo lsusb -d 046d:086b -v | grep “14 Video” prints:
bFunctionClass 14 Video
bInterfaceClass 14 Video
can't get debug descriptor: Resource temporarily unavailable
After plugging my webcam to USBH4 port, dmesg | tail prints such logs:
[ 851.918807] usb 2-1: new SuperSpeed USB device number 7 using cdns-usb3
[ 851.946369] usb 2-1: current rate 16000 is different from the runtime rate 24000
[ 851.948813] usb 2-1: current rate 16000 is different from the runtime rate 32000
[ 851.951303] usb 2-1: current rate 16000 is different from the runtime rate 48000
[ 851.958733] input: BRIO 4K Stream Edition as /devices/platform/5b110000.usb3/xhci-cdns3/usb2/2-1/2-1:1.4/0003:046D:086B.0002/input/input3
[ 852.019141] hid-generic 0003:046D:086B.0002: input,hidraw0: USB HID v1.11 Device [BRIO 4K Stream Edition] on usb-xhci-cdns3-1/input4
lsusb
Bus 002 Device 006: ID 046d:086b Logitech, Inc. BRIO 4K Stream Edition
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 004: ID 1286:204e Marvell Semiconductor, Inc.
Bus 004 Device 002: ID 0424:3503 Standard Microsystems Corp.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ci_hdrc/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/3p, 480M
|__ Port 1: Dev 3, If 0, Class=Wireless, Driver=btusb, 480M
|__ Port 1: Dev 3, If 1, Class=Wireless, Driver=btusb, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ci_hdrc/1p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=/1p, 5000M
|__ Port 1: Dev 6, If 0, Class=Video, Driver=, 5000M
|__ Port 1: Dev 6, If 1, Class=Video, Driver=, 5000M
|__ Port 1: Dev 6, If 2, Class=Audio, Driver=snd-usb-audio, 5000M
|__ Port 1: Dev 6, If 3, Class=Audio, Driver=snd-usb-audio, 5000M
|__ Port 1: Dev 6, If 4, Class=Human Interface Device, Driver=usbhid, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=/1p, 480M
My Dockerfile for checking connected devices:
FROM torizon/arm64v8-debian-wayland-base-vivante
RUN apt-get -y update && apt-get install v4l-utils
CMD ["v4l2-ctl", "--list-devices"]
My docker-compose file:
version: "2.4"
services:
weston:
image: torizon/arm64v8-debian-weston-vivante:latest
network_mode: host
environment:
- ACCEPT_FSL_EULA=1
devices:
- /dev/video0:/dev/video0
- /dev/video1:/dev/video1
- /dev/video2:/dev/video2
- /dev/video3:/dev/video3
- /dev/video4:/dev/video4
- /dev/video5:/dev/video5
- /dev/video6:/dev/video6
- /dev/video7:/dev/video7
- /dev/video8:/dev/video8
- /dev/video9:/dev/video9
- /dev/video10:/dev/video10
- /dev/video12:/dev/video12
- /dev/video13:/dev/video13
volumes:
- type: bind
source: /tmp
target: /tmp
- type: bind
source: /run/udev
target: /run/udev
- type: bind
source: /dev
target: /dev
cap_add:
- CAP_SYS_TTY_CONFIG
# Add device access rights through cgroup...
device_cgroup_rules:
# ... for tty0
- 'c 4:0 rmw'
# ... for tty7
- 'c 4:7 rmw'
# ... for /dev/input devices
- 'c 13:* rmw'
- 'c 199:* rmw'
# ... for /dev/dri devices
- 'c 226:* rmw'
- 'c 81:* rmw'
formats:
image: alexey777/formats:latest
devices:
volumes:
- /tmp:/tmp
- /dev:/dev
- /sys:/sys
Console output:
weston_1 | [09:55:26.316] event1 - BRIO 4K Stream Edition: is tagged by udev as: Keyboard
weston_1 | [09:55:26.316] event1 - BRIO 4K Stream Edition: device is a keyboard
formats_1 | Failed to open /dev/video0: Invalid argument
formats_1 | vpu B0 (platform:):
formats_1 | /dev/video12
formats_1 | /dev/video13
formats_1 |
formats_1 | mxc-isi (platform:58100000.isi.0):
formats_1 | /dev/video8
formats_1 |
formats_1 | mxc-isi (platform:58140000.isi.4):
formats_1 | /dev/video4
formats_1 |
formats_1 | mxc-isi (platform:58150000.isi.5):
formats_1 | /dev/video5
formats_1 |
formats_1 | mxc-isi (platform:58160000.isi.6):
formats_1 | /dev/video6
formats_1 |
formats_1 | mxc-isi (platform:58170000.isi.7):
formats_1 | /dev/video7
formats_1 |
formats_1 | mxc-jpeg decoder (platform:58400000.jpegdec):
formats_1 | /dev/video9
formats_1 |
formats_1 | mxc-jpeg decoder (platform:58450000.jpegenc):
formats_1 | /dev/video10
formats_1 |
Full console output:
Creating torizon_formats_1 ...
Creating torizon_weston_1 ... done
[ 1461.939832] (null): mxc_isi_capture_open, No remote pad found!
[ 1461.945760] (null): mxc_isi_capture_open, No remote pad found!
Creating torizon_formats_1 ... done
[ 1461.958009] (null): mxc_isi_capture_open, No remote pad found!
Attaching to torizon_weston_1, torizon_formats_1
weston_1 | Switching to VT 7
weston_1 | NXP EULA has already been accepted.
weston_1 | touch: cannot touch '/tmp/nxp-eula-accepted': Permission denied
(eston_1 | Date: [2 012406-20.70-07313 5U8T]C
n[l3l3)m:w emxstc_oni_s1i _ c a|p[u0rme _[o0p9en:5,5 :N2o6 .re2m46o]t ew epsatdo nf o5u.n0d.!0
weston_1 | https://wayland.freedesktop.org
weston_1 | Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/
weston_1 | Build: unknown (not built from git or tarball)
weston_1 | [09:55:26.247] Command line: /usr/bin/weston --current-mode
weston_1 | [09:55:26.247] OS: Linux, 4.14.170-4.0.0-devel+git.fb6b17a22634, #1-TorizonCore SMP PREEMPT Mon May 11 14:38:24 UTC 2020, aarch64
weston_1 | [09:55:26.248] Using config file '/etc/xdg/weston/weston.ini'
weston_1 | [09:55:26.249] Output repaint window is 16 ms maximum.
weston_1 | [09:55:26.249] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/drm-backend.so'
weston_1 | [09:55:26.251] initializing drm backend
weston_1 | [09:55:26.253] using /dev/dri/card0
weston_1 | [09:55:26.253] DRM: supports universal planes
weston_1 | [09:55:26.253] DRM: supports atomic modesetting
weston_1 | [09:55:26.254] DRM: does not support picture aspect ratio
weston_1 | [09:55:26.254] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/gl-renderer.so'
weston_1 | [09:55:26.277] EGL client extensions: EGL_EXT_client_extensions
weston_1 | EGL_EXT_platform_base EGL_KHR_platform_wayland
weston_1 | EGL_EXT_platform_wayland EGL_KHR_platform_gbm
weston_1 | [09:55:26.285] warning: neither EGL_EXT_swap_buffers_with_damage or EGL_KHR_swap_buffers_with_damage is supported. Performance could be affected.
[ 1462.113581] Timeout for IPC response!
weston_1 | [09:55:26.285] EGL_KHR_surfaceless_context available
weston_1 | [09:55:26.303] EGL version: 1.5
weston_1 | [09:55:26.303] EGL vendor: Vivante Corporation
weston_1 | [09:55:26.303] EGL client APIs: OpenGL_ES
weston_1 | [09:55:26.303] EGL extensions: EGL_KHR_fence_sync EGL_KHR_reusable_sync
weston_1 | EGL_KHR_wait_sync EGL_KHR_image EGL_KHR_image_base
weston_1 | EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image
weston_1 | EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image
weston_1 | EGL_EXT_image_dma_buf_import
weston_1 | EGL_EXT_image_dma_buf_import_modifiers EGL_KHR_lock_surface
weston_1 | EGL_KHR_create_context EGL_KHR_surfaceless_context
weston_1 | EGL_EXT_buffer_age EGL_ANDROID_native_fence_sync
weston_1 | EGL_WL_bind_wayland_display
weston_1 | EGL_WL_create_wayland_buffer_from_image EGL_KHR_partial_update
weston_1 | [09:55:26.303] GL version: OpenGL ES 3.2 V6.2.4.p4.190076
weston_1 | [09:55:26.303] GLSL version: OpenGL ES GLSL ES 3.20
weston_1 | [09:55:26.303] GL vendor: Vivante Corporation
weston_1 | [09:55:26.303] GL renderer: Vivante GC7000XSVX
weston_1 | [09:55:26.303] GL extensions: GL_OES_vertex_type_10_10_10_2
weston_1 | GL_OES_vertex_half_float GL_OES_element_index_uint
weston_1 | GL_OES_mapbuffer GL_OES_vertex_array_object
weston_1 | GL_OES_compressed_ETC1_RGB8_texture
weston_1 | GL_OES_compressed_paletted_texture GL_OES_texture_npot
weston_1 | GL_OES_rgb8_rgba8 GL_OES_depth_texture
weston_1 | GL_OES_depth_texture_cube_map GL_OES_depth24 GL_OES_depth32
weston_1 | GL_OES_packed_depth_stencil GL_OES_fbo_render_mipmap
weston_1 | GL_OES_get_program_binary GL_OES_fragment_precision_high
weston_1 | GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_EGL_sync
weston_1 | GL_OES_texture_stencil8 GL_OES_shader_image_atomic
weston_1 | GL_OES_sample_variables GL_OES_sample_shading
weston_1 | GL_OES_texture_storage_multisample_2d_array
weston_1 | GL_OES_shader_multisample_interpolation
weston_1 | GL_OES_required_internalformat GL_OES_surfaceless_context
weston_1 | GL_OES_copy_image GL_OES_draw_buffers_indexed
weston_1 | GL_OES_geometry_shader GL_OES_geometry_point_size
weston_1 | GL_OES_gpu_shader5 GL_OES_shader_io_blocks
weston_1 | GL_OES_texture_border_clamp GL_OES_texture_buffer
weston_1 | GL_OES_tessellation_shader GL_OES_tessellation_point_size
weston_1 | GL_OES_texture_cube_map_array GL_OES_draw_elements_base_vertex
weston_1 | GL_OES_texture_half_float GL_OES_texture_float
weston_1 | GL_OES_primitive_bounding_box
weston_1 | GL_KHR_texture_compression_astc_ldr
weston_1 | GL_KHR_blend_equation_advanced GL_KHR_debug GL_KHR_robustness
weston_1 | GL_EXT_texture_type_2_10_10_10_REV
weston_1 | GL_EXT_texture_filter_anisotropic
weston_1 | GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888
weston_1 | GL_EXT_texture_compression_s3tc GL_EXT_read_format_bgra
weston_1 | GL_EXT_multi_draw_arrays GL_EXT_frag_depth
weston_1 | GL_EXT_discard_framebuffer GL_EXT_blend_minmax
weston_1 | GL_EXT_multisampled_render_to_texture
weston_1 | GL_EXT_color_buffer_half_float GL_EXT_color_buffer_float
weston_1 | GL_EXT_robustness GL_EXT_texture_sRGB_decode
weston_1 | GL_EXT_draw_buffers_indexed GL_EXT_texture_border_clamp
weston_1 | GL_EXT_texture_buffer GL_EXT_tessellation_shader
weston_1 | GL_EXT_tessellation_point_size GL_EXT_geometry_shader
weston_1 | GL_EXT_geometry_point_size GL_EXT_copy_image
weston_1 | GL_EXT_texture_cube_map_array GL_EXT_gpu_shader5
weston_1 | GL_EXT_shader_io_blocks GL_EXT_shader_implicit_conversions
weston_1 | GL_EXT_multi_draw_indirect GL_EXT_draw_elements_base_vertex
weston_1 | GL_EXT_texture_rg GL_EXT_primitive_bounding_box GL_EXT_sRGB
weston_1 | GL_ANDROID_extension_pack_es31a GL_VIV_direct_texture
weston_1 | [09:55:26.303] GL ES 2 renderer features:
weston_1 | read-back format: BGRA
weston_1 | wl_shm sub-image to texture: yes
weston_1 | EGL Wayland extension: yes
weston_1 | [09:55:26.318] event0 - sc-powerkey: is tagged by udev as: Keyboard
weston_1 | [09:55:26.318] event0 - sc-powerkey: device is a keyboard
weston_1 | [09:55:26.331] event2 - colibri-vf50-ts: is tagged by udev as: Touchscreen
weston_1 | [09:55:26.331] event2 - colibri-vf50-ts: device is a touch device
weston_1 | [09:55:26.363] Touchscreen - colibri-vf50-ts - /sys/devices/platform/vf50-touchscreen/input/input2/event2
weston_1 | [09:55:26.364] input device event2 has no enabled output associated (none named), skipping calibration for now.
weston_1 | [09:55:26.364] DRM: head 'HDMI-A-1' found, connector 146 is disconnected.
weston_1 | [09:55:26.364] Registered plugin API 'weston_drm_output_api_v1' of size 24
weston_1 | [09:55:26.365] Compositor capabilities:
weston_1 | arbitrary surface rotation: yes
weston_1 | screen capture uses y-flip: yes
weston_1 | presentation clock: CLOCK_MONOTONIC, id 1
weston_1 | presentation clock resolution: 0.000000001 s
weston_1 | [09:55:26.366] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
weston_1 | [09:55:26.369] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
weston_1 | [09:55:26.377] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/xwayland.so'
weston_1 | [09:55:26.409] Registered plugin API 'weston_xwayland_v1' of size 32
weston_1 | [09:55:26.409] Registered plugin API 'weston_xwayland_surface_v1' of size 16
weston_1 | [09:55:26.410] xserver listening on display :0
weston_1 | [09:55:26.410] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
weston_1 | could not load cursor 'dnd-move'
weston_1 | could not load cursor 'dnd-copy'
weston_1 | could not load cursor 'dnd-none'
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
When I connect my webcam to USBH3 port, I dmesg | tail prints such logs:
[ 1231.882749] usb 4-1.3: new high-speed USB device number 5 using ci_hdrc
[ 1231.999328] usb 4-1.3: current rate 16000 is different from the runtime rate 24000
[ 1232.001816] usb 4-1.3: current rate 16000 is different from the runtime rate 32000
[ 1232.004459] usb 4-1.3: current rate 16000 is different from the runtime rate 48000
lsusb
Bus 004 Device 005: ID 046d:086b Logitech, Inc.
lsusb -t
|__ Port 1: Dev 4, If 0, Class=Wireless, Driver=btusb, 480M
|__ Port 1: Dev 4, If 1, Class=Wireless, Driver=btusb, 480M
|__ Port 3: Dev 5, If 0, Class=Video, Driver=, 480M
|__ Port 3: Dev 5, If 1, Class=Video, Driver=, 480M
|__ Port 3: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 5, If 3, Class=Audio, Driver=snd-usb-audio, 480M
Console output when the webcam is connected via USBH3:
[ 2617.086942] (null): mxc_isi_capture_open, No remote pad found!
[ 2617.092978] (null): mxc_isi_capture_open, No remote pad found!
[ 2617.098996] (null): mxc_isi_capture_open, No remote pad found!
[ 2617.104985] (null): mxc_isi_capture_open, No remote pad found!
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
formats_1 |
weston_1 | Date: 2020-07-31 UTC
weston_1 | [10:14:41.482] weston 5.0.0
weston_1 | [10:14:41.483] Command line: /usr/bin/weston --current-mode
weston_1 | [10:14:41.483] OS: Linux, 4.14.170-4.0.0-devel+git.fb6b17a22634, #1-TorizonCore SMP PREEMPT Mon May 11 14:38:24 UTC 2020, aarch64
weston_1 | [10:14:41.483] Using config file '/etc/xdg/weston/weston.ini'
weston_1 | [10:14:41.484] Output repaint window is 16 ms maximum.
weston_1 | [10:14:41.484] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/drm-backend.so'
weston_1 | [10:14:41.486] initializing drm backend
weston_1 | [10:14:41.490] using /dev/dri/card0
weston_1 | [10:14:41.490] DRM: supports universal planes
weston_1 | [10:14:41.491] DRM: supports atomic modesetting
weston_1 | [10:14:41.491] DRM: does not support picture aspect ratio
weston_1 | [10:14:41.491] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/gl-renderer.so'
weston_1 | [10:14:41.507] EGL client extensions: EGL_EXT_client_extensions
weston_1 | [10:14:41.515] warning: neither EGL_EXT_swap_buffers_with_damage or EGL_KHR_swap_buffers_with_damage is supported. Performance could be affected.
weston_1 | [10:14:41.515] EGL_KHR_surfaceless_context available
weston_1 | [10:14:41.524] EGL version: 1.5
weston_1 | [10:14:41.524] EGL vendor: Vivante Corporation
weston_1 | [10:14:41.524] EGL client APIs: OpenGL_ES
weston_1 | [10:14:41.524] EGL extensions: EGL_KHR_fence_sync EGL_KHR_reusable_sync
weston_1 | [10:14:41.524] GL version: OpenGL ES 3.2 V6.2.4.p4.190076
weston_1 | [10:14:41.524] GLSL version: OpenGL ES GLSL ES 3.20
weston_1 | [10:14:41.524] GL vendor: Vivante Corporation
weston_1 | [10:14:41.524] GL renderer: Vivante GC7000XSVX
weston_1 | [10:14:41.524] GL extensions: GL_OES_vertex_type_10_10_10_2
weston_1 | [10:14:41.525] GL ES 2 renderer features:
weston_1 | [10:14:41.538] event0 - sc-powerkey: is tagged by udev as: Keyboard
weston_1 | [10:14:41.538] event0 - sc-powerkey: device is a keyboard
weston_1 | [10:14:41.552] event1 - colibri-vf50-ts: is tagged by udev as: Touchscreen
weston_1 | [10:14:41.552] event1 - colibri-vf50-ts: device is a touch device
weston_1 | [10:14:41.578] Touchscreen - colibri-vf50-ts - /sys/devices/platform/vf50-touchscreen/input/input1/event1
weston_1 | [10:14:41.578] input device event1 has no enabled output associated (none named), skipping calibration for now.
weston_1 | [10:14:41.579] DRM: head 'HDMI-A-1' found, connector 146 is disconnected.
weston_1 | [10:14:41.580] Registered plugin API 'weston_drm_output_api_v1' of size 24
weston_1 | [10:14:41.580] Compositor capabilities:
weston_1 | [10:14:41.581] Loading module '/usr/lib/aarch64-linux-gnu/weston/desktop-shell.so'
weston_1 | [10:14:41.584] launching '/usr/lib/aarch64-linux-gnu/weston-keyboard'
weston_1 | [10:14:41.595] Loading module '/usr/lib/aarch64-linux-gnu/libweston-5/xwayland.so'
weston_1 | [10:14:41.616] Registered plugin API 'weston_xwayland_v1' of size 32
weston_1 | [10:14:41.616] Registered plugin API 'weston_xwayland_surface_v1' of size 16
weston_1 | [10:14:41.616] xserver listening on display :0
weston_1 | [10:14:41.616] launching '/usr/lib/aarch64-linux-gnu/weston-desktop-shell'
