I have successfully downloaded the torizon image with toradex easy installer. Now it is asking for login details. As referred to some of the questions asked by other users who faced the same problem on toradex community, I entered login as ‘root’ and left the password blank and entered. It shows login incorrect error.
Deven is correct here but just to add more information. Unlike our other BSP Torizon has root login disabled by default, this is because we aim for Torizon to be a production ready distribution. Therefore disabling root login is just a simple security stance towards that end.
I’m using the Apalis iMX8 QuadMax with the Ixora Carrier Board, and the password “torizon” is not working. Is there another password that I need to use for the default password on my first login?
The torizon login is used for our “TorizonCore” images. For our non-TorizonCore images the login is just root. So it depends on what image you’re running basically.
I’m using Putty and/or WinSCP to connect with the Toradex Embedded Linux console. I used the root per your suggestion and that worked. When should I use the torizon login?
